All Part Number Request Go Here
Old Sep 9, 2021 | 07:45 AM
  #4681
Originally Posted by tuckhen10
Hey everyone I was wondering if the the shifter garnish ring: Part # MR572847 is the same ring that goes around the airbag, or if it will fit around the airbag?MRR57284757
@tuckhen10 The website does not show any separate parts to the steering wheel. Hard to believe it would be the same item. You can look it up here if you like :https://partsouq.com/
Old Sep 9, 2021 | 08:08 AM
  #4682
tuckhen10's Avatar
I know they don't show any separate parts for the steering wheel, but it looks so similar I was just wondering.
I'm wanting to buy an Evo 8-9 steering wheel for 2g Eclipse GSX, but some of them don't have that airbag ring.
I'm ok with one one without an airbag, and I cant make a WTB post on this forum, because I don't have those privileges yet.
Old Sep 9, 2021 | 10:03 AM
  #4683
You just need a few more posts & you will OK to post up in the Market Place
Old Mar 11, 2022 | 09:09 AM
  #4684
Vysirath's Avatar
Hi, does anyone know what the part number is for the interior trim panel to the left of the gauge cluster. I'm looking specifically for the panel with the mirror and foglight cutouts in the carbon fiber pattern for an 04 Ralliart? I can only find the black and beige ones. Thanks!
Old Mar 11, 2022 | 09:32 AM
  #4685
This has been a good site to search. I use it frequently
Old May 21, 2022 | 04:35 PM
  #4686
kamarul's Avatar
hanger crossmember evo 3/gsr
Hello all member do you know the part number for the Hanger Crossmember evo3/gsr this
I need the number part for the Hanger Crossmember Awd evo 3 in the red circle mark..
Old May 22, 2022 | 12:59 PM
  #4687
jarretpcurry's Avatar
Charcoal Canister Removal (HELP!)
Still trying to source this white plastic piece (15). Worst case scenario can I just throw a breather valve on the line (2)? Saw a breather mentioned in a couple of posts but no response.
Old May 22, 2022 | 03:33 PM
  #4688
Looks like it might be part no. MR597135 (05951)
Old May 22, 2022 | 05:19 PM
  #4689
No pictures online but at ten bucks I think I’ll take a chance. Thanks so much.
Old May 23, 2022 | 07:28 AM
  #4690
Kevin.'s Avatar
https://www.evolutionm.net/forums/ev...l#post11944344
Where did you vent up front, @ViciousLSD ?
I'm also removing evap and replacing filler neck at the moment. I assume the white piece uses a push-style mount in the LR frame rail?
Old May 23, 2022 | 09:02 AM
  #4691
ViciousLSD's Avatar
I used a check valve (that can hold back some pressure) then routed it back the existing evap line. the hose in the engine bay is open/hanging at the moment. no fuel smell in my garage. that white thing on the frame lets the fuel smell out, and would probably bring moisture in to the tank
Old May 25, 2022 | 03:36 PM
  #4692
Order was just canceled because the part is no longer available. Back to the breather idea?
Old May 25, 2022 | 06:41 PM
  #4693
Does this valve have an electrical connection as well? If it doesnt i would think a generic type of check valve could be used?
Old May 27, 2022 | 08:08 AM
  #4694
Kevin.'s Avatar
Check valve #12
Old Jul 22, 2022 | 11:51 AM
  #4695
Rockie's Avatar
EVO 9 Gearbox
Hello everyone please could anyone confirm if part number W5M511X7A UVO473 is an RS or GSR gearbox
Many Thanks
