All Part Number Request Go Here
I'm pretty sure this was answered, but I can't find it on the list. Sorry if it is. 1. The plastic part that goes around the foglight switch and mirror adjuster. 2. The clear instrument cluster covering. (The clear plastic part over the tach, speedo, gauges, etc.) Thanks.
Originally Posted by EvoBig16G
I need the part number for a cubby hole where the radio currently sits. I think the EVO RS comes with this cubby hole since it doesn't come with a stock radio. Evo RS DIN kit?
It is the cubby in this picture except in the stock radio location. I think it's the same part. Thanks.
MR633897 is Aug 2004 and up
It is safe to assume the difference in these parts is the later is probably ACD.
If you don't have it you should stick with the first part #.
MR951468 is the clear combination meter cover.
Originally Posted by RKT SHP
does anyone know the part number for those little metal clips that hold the fuel injectors on because i lost one of mine
MN119784 (Manifold-Turbine) Stud
MR224441 (Turbine-O2) Stud
MR323654 Exhaust Manifold to turbo gasket
MR323654 Exhaust Manifold gasket (head to manifold)
These are the right part numbers for a 10.5T install and new 02 housing and manifold install ,correct?
turbine to 02 , 6 in total. Correct?
manifold to turbo 4 needed . correct?
I thought there were two part numbers for the 4 mani to turbine housing bolts?
Exhaust manifold gasket: MR323654
Exhaust manifold washers: MD050076 x2, MD041192 x7
Exhaust manifold nuts: MR224500 x2, MR212302 x7
Turbine housing gasket: MR404547
Exhaust manifold-turbine housing bolt: MN119783 x2
Exhaust manifold-turbine housing washer: MD132933 x9*
Exhaust manifold-turbine housing nut: MD132930 x2
Exhaust manifold-turbine housing stud: MN119784 x2
Turbine housing-O2 housing gasket: MR299686
Turbine housing-O2 housing stud: MR224441 x2
Turbine housing-O2 housing bolt: MD062961 x3
Turbine housing-02 housing nut: MD050073 x2
Compressor outlet gasket: MR281085
Oil feed line crush washer (head): MF660063 x2
Oil feed line crush washer (turbo): MF660064 x2
Oil drain line gasket (turbo): MR258477
Oil drain line gasket (oil pan): MN156738
* These washers are also used on the O2 housing. Order a total of 9 for a complete install, or only 4 if you are not removing the turbine housing.
Is this All needed? I am only doing a manifold swap, Turbine housing swap, and a 02 housing swap. thanks in advance
