All Part Number Request Go Here
Old Aug 5, 2005 | 10:18 AM
  #706
JustDSM's Avatar
Lower cussion: MN151113XA
Back cussion: MN151111XA
Also, the foam is not avail. seperately from the material. You've got to buy it complete.
Old Aug 5, 2005 | 10:31 AM
  #707
Doug@WGP's Avatar
Originally Posted by JustDSM
I gave you the PN for the PNC (the number you gave me)
In any case, here's the "#6" O-Ring: MR431119
I thought part #11 is the "o-ring"
My service manual lists #6 as a "spacer"
Old Aug 5, 2005 | 02:20 PM
  #708
chrisw's Avatar
I need the part number for the dome light and sun glasses holder assembly for EVOs with no sunroof
Old Aug 5, 2005 | 03:31 PM
  #709
timzcat's Avatar
MR794300
That is everything, bulbs, lens, entire sunglass pocket.
Old Aug 5, 2005 | 05:06 PM
  #710
rcheung's Avatar
Does anyone have the part number for the key sense switch under the upper steering colum behind the key cylinder?
I broke mine and now my keyless entry wont work unless I connect the green wires together behind switch.
Old Aug 5, 2005 | 05:23 PM
  #711
Thegame's Avatar
Originally Posted by timzcat
MR633896 is 2003 to Aug 2004
MR633897 is Aug 2004 and up
It is safe to assume the difference in these parts is the later is probably ACD.
If you don't have it you should stick with the first part #.
MR951468 is the clear combination meter cover.
For the first two numbers, I ordered the first one and it doesn't have the foglight cutout. I now realize that acd and foglights are the exact same, so the one I ordered was for the RS. Anyone else should go with part #2.
Old Aug 5, 2005 | 07:14 PM
  #712
timzcat's Avatar
I just looked it up again and must have looked at the RS listing because the gsr on shows the second number. I apoligize for the mistake.
Old Aug 6, 2005 | 11:01 PM
  #713
justchil's Avatar
Need part # for the coil pack.. just need one.. the one on the drivers side (i think they are the same)
Old Aug 6, 2005 | 11:34 PM
  #714
JustDSM's Avatar
MD623072
Old Aug 6, 2005 | 11:36 PM
  #715
timzcat's Avatar
MD363552 with the COP boot.
Old Aug 7, 2005 | 01:31 AM
  #716
justchil's Avatar
just realized it was on the first post.. sorry about that. $113 to make my car run .. doesn't sound too bad
Old Aug 7, 2005 | 08:45 PM
  #717
Blackie9900's Avatar
found out today that my cousins friend gets 50% off at .. any one got the partnumbers for the 10.5 housing? and the accesories that goes along with it... thanks
or if the tme comes from mitsu.. maybe i can get a price for it.. all i need is a partnumber..
Old Aug 7, 2005 | 08:54 PM
  #718
timzcat's Avatar
Nope. They are both JDM EDM parts not USDM so no part numbers.
There is a new 10.5 USDM but it's over 500 and you can still get the old one for 200 or so.
Old Aug 7, 2005 | 09:04 PM
  #719
damm... so asically im better off buying a 2005 turbo from someone .. (is there any performance differance between the jdm and the usdm.. like the wastegate..? or no one knows yet ?
Old Aug 7, 2005 | 09:26 PM
  #720
fixem2's Avatar
Looking for the part number for the Coupler that connects the Upper Intercooler pipe to the intercooler. (this is the coupler right behind the front bumper.)
Thank you.
