All Part Number Request Go Here
Old Aug 29, 2005 | 06:06 PM
  #751
Doug@WGP's Avatar
Originally Posted by timzcat
MR572609 Board, trunk room floor 2003
MR572601 Trim, Trunk room side LH Gray
MR572602 Trim, Trunk room side RH Gray
does the carpet come w/ the board?
Old Aug 29, 2005 | 06:07 PM
  #752
timzcat's Avatar
Originally Posted by rcheung
2003 Evo
Does anyone have the part number for the gauge cluster housing? The grey plastic piece which is held in by two screws on top and has to be removed before removing the gauge cluster.
MR506452 Bezel, Combination Meter
Old Aug 29, 2005 | 06:08 PM
  #753
timzcat's Avatar
Yes it's attached to the board.
Old Aug 29, 2005 | 06:12 PM
  #754
timzcat's Avatar
Originally Posted by webguy330i
OK, quick question on bolt size.
I need to know the measurements of the downpipe -> o2 housing bolt. I have the bolt (no part # off hand sorry) but I may need to retap the o2 housing hole.
Thanks!!
Size is not listed for the downpipe bolts. Ask in Evo General I am sure no someone knows the thread size.
Old Aug 29, 2005 | 06:18 PM
  #755
timzcat's Avatar
Originally Posted by WarmPepsi
nice.
question on how the system seperates the brake lines. Went to install aftermarket lines to replace the rubber ones, but as soon as i put a wrench on the 10 mm holder bolt, it just rounded like icing on a cake.
Not an issue now, but the lines aren't installed now. couldn't bust it loose, so nothing could be done.
Quick version. How does mitsu seperate the metal lines from the distributing block to the connection by the wheel? Fronts esp. Thanks.
What is it you want?
Part number for the hardline?
Old Aug 29, 2005 | 06:40 PM
  #756
webguy330i's Avatar
Thanks tim!
Old Aug 30, 2005 | 01:26 PM
  #757
hkfeet's Avatar
Hey timz and justin, Im looking for the battery fuse part #. Its the one located on the positive terminal, thanks
Old Aug 30, 2005 | 04:20 PM
  #758
timzcat's Avatar
Refresh my memory, it is not just a fuse but it's the block the fuse is mounted on too, right?
That is what it appears to be in the book. There is no actual fuse listed.
They call it a fusible link 100Amp
For build 12/02 to 07/03 it is MR522172
For build 07/03 to 07/04 it is MN164187
For builds 08/04 onwards it is MR 583955
Old Sep 1, 2005 | 08:41 PM
  #759
platinumspecv's Avatar
Need part # for CV boot on 03 Evo. Thanks
Old Sep 1, 2005 | 10:36 PM
  #760
hkfeet's Avatar
Armrest for 03
and Armrest/SSL
Old Sep 1, 2005 | 10:37 PM
  #761
hkfeet's Avatar
Thanks timz, will try those
Old Sep 1, 2005 | 10:55 PM
  #762
timzcat's Avatar
MR633889 for suede style 03-05
MR652378 must be SSL because it is the only other number listed. (option A68 or K03?)
Old Sep 1, 2005 | 10:59 PM
  #763
hkfeet's Avatar
Err expensive. I hate getting rapped off these little parts.
Old Sep 1, 2005 | 11:00 PM
  #764
hkfeet's Avatar
Front o2 sensor
Rear o2 sensor
Old Sep 1, 2005 | 11:04 PM
  #765
timzcat's Avatar
MN156750 Boot kit, Front Axle Shaft (LH, RH)
MN156751 Boot kit, Front Joint (LH,RH)
Be specific as too which one you need so I can verify the part number.
