Best BOV to use
Old Mar 16, 2005 | 08:59 AM
Rookie's Avatar
Best BOV to use
Hey I'm new to the AWD and world of EVO's......i got white 03 evo about a month ago....I am goin to do a cat back exhaust and air intake so i still got my factory warranty . But the main question is what would be the best blow off valve to use? i dont know much about the turbo world...so any help u guys could give me would be greatly appreciated.
Old Mar 16, 2005 | 09:02 AM
mike69's Avatar
I recommend keeping the stock BPV.
Old Mar 16, 2005 | 09:03 AM
Kwman's Avatar
Unless your upping the boost. Stock is fine. Otherwise i strongly reccomend the JDM MR BPV.
Old Mar 16, 2005 | 09:04 AM
Eveolicious's Avatar
The HKS SSQV seems to be a nice BOV, I see some Evo's around here have that. Sounds awesome too!
Old Mar 16, 2005 | 09:06 AM
EVOL EDO's Avatar
stock unless it leaks like mine, mr if u want something that works and is cheap to replace, also i havnt heard anything bad about the APS blow off valve(which i should recieve today)
ultraflip's Avatar
SSQV is a great valve... although many have had problems with it... then again... others have had zero problems...
i have the greddy type RS... really nice valve.. holds boost fine... haven't had any problems VTA...
best valve i've seen is the greddy type S though... it has has secondary hose on it that 'makes' the valve open when it's suppose to open... no surge
Old Mar 16, 2005 | 09:08 AM
quazimoto88's Avatar
I would go with the MR BOV. I used the HKS SSQV and I had idling problems. Didn't seem to give any more power but sounded good. If you go with HKS you would probably need to get the HKS electronic idle stablizer to get perfect idling. I am currently using the MR BOV with no probelms at all.
Old Mar 16, 2005 | 09:11 AM
turtlelancer's Avatar
Um i dont think BOV's are suppose to give power..... correct me if im wrong
Kwman's Avatar
You don't need to spend the extra money on an HKS or greddy unless you REALLY want that VTA whistle. Just get the MR and recirc and avoid the headaches and its still JDM so you can still brag about it if you want....
Old Mar 16, 2005 | 09:15 AM
mike69's Avatar
^^--What he said
Old Mar 16, 2005 | 10:02 AM
Alias's Avatar
Keep it stock unless you know it is leaking or you are upping your boost.
Old Mar 16, 2005 | 10:17 AM
Aikido's Avatar
I own the greddy type S, make sure to set it right though, by this i mean open it take the smaller inside spring out and adjust the stiffness of your type-S accordingly. If you decide to get a type-S pm me and i'll give you the directions for setting it up.
Adam
Old Mar 16, 2005 | 10:19 AM
EVOL EDO's Avatar
^^ yeah what alias said so make sure you have a boost gauge. and changing the bov wont add power unless it is leaking which will cause a drop in power because it cant hold boost
Old Mar 16, 2005 | 10:46 AM
Just a curious question... since I don't currently own an Evo yet. Does the stock BOV still whistle, and make the typical "BOV sound"?
Old Mar 16, 2005 | 11:06 AM
Alias's Avatar
Not really....or at least at a very minimum noise level. Unless you have an open air element, you will barely hear it, which is ok with me since I think it is just rice to get a bov for the noise.
