Question about boost
Old Mar 19, 2005 | 05:19 PM
bigjhoney's Avatar
Just installed my boost gauge. Ive read that boost should spike to 19.5 and level off to 16. My boost is spiking at 21 and leveling off to about 16/17. Only mods I have are a 3 inch rnr catback exhaust, and an hks drop in filter. Cars running good, just making sure if this should be right.
Old Mar 19, 2005 | 05:20 PM
hueman's Avatar
exhaust might make it spike a bit. the gauge may be off a bit as well
Old Mar 19, 2005 | 05:21 PM
Shaker Motorsports's Avatar
That sounds normal. Get an MBC or EBC and an MR diverter valve to control the boost.
Old Mar 19, 2005 | 05:25 PM
hutch959's Avatar
why would the diverter valve control the boost??/
i would think it may hold the boost better... but only if the stock one was leaking.
And the stock one should not leak at those pressures
Old Mar 19, 2005 | 06:28 PM
DCSilvrEvo's Avatar
yea get an MBC or Electronic one(better) you will hold X amount of boost till redline!
Old Mar 20, 2005 | 05:16 AM
With that kind of number, he might be experiencing leakage. It is a cheap and beneficial upgrade that will prevent that leakage, thus controlling boost better.
Old Mar 20, 2005 | 02:23 PM
mdosu's Avatar
actually hold it for longer peroids of time...the stock does leak, that's why we get the 19.5 spike. He's just double checking whether his new meter is cause of the spike...
I say check your hosing...plus...where did you tap your "T"? There's been huge debates on where to put it...one place was where factory puts them, but the other place is suppose to give more accurate readings.
Old Mar 20, 2005 | 03:50 PM
bigjhoney's Avatar
put it in the other place, the shorter line. It was a PITA to get the fitting to go on that small hose.
talek
Mar 16, 2011 07:16 PM
Inflation
10
Jun 12, 2008 07:14 AM
SWOLN
Mar 31, 2008 03:09 PM
Noize
28
Jan 30, 2007 07:41 AM
Fourdoor
12
Nov 7, 2004 08:45 PM
