View Poll Results: What RPM's Do You Launch At?
3K to 3.5K
10
5.88%
3.5K to 4K
27
15.88%
4K to 4.5K
34
20.00%
4.5K to 5K
43
25.29%
5K to 6K
45
26.47%
6K to 7K
11
6.47%
Voters: 170. You may not vote on this poll
Old Apr 3, 2005 | 11:38 AM
Turbo13's Avatar
Thumbs up What RPM's Do You Launch At?
Hey guys was just curious what majority of you all launch at. Also if you could list if your car is modified and to what extent.
Old Apr 3, 2005 | 11:42 AM
RalliArtEvoVIII's Avatar
i like to launch at 8600rpms usually...
so wait...u dyno'd 316 with just
B&B Turbo Back Exhaust
B&B Cat Delete Pipe
Hallman MBC
Walbro 255
Grounding Kit???
what the hell was ur MBC set at what gas were u using???!?!
Old Apr 3, 2005 | 11:49 AM
rlazer5000's Avatar
B&B Cat Delete Pipe
Hallman MBC
Walbro 255
Grounding Kit???
I assume ur joking, otherwise id ask u to prove it .......im still on the stock clutch, so a good 5K RPM launch is a really harsh, but ive only done a couple times. I have a lot of mods getting installed in the next couple months, and hopefully ill get a clutch as well. I guess we'll see how that goes considering its gonna cost me a lot of $$$ for the clutch plus labor. Oh well, bankruptcy here i come!
Old Apr 3, 2005 | 11:59 AM
Turbo13's Avatar
B&B Cat Delete Pipe
Hallman MBC
Walbro 255
Grounding Kit???
Set at 23PSI on 91 **** gas. I turn it down around town, but on 20 it still did 304 so....I can't wait to get my other stuff on and go back. So what do you really launch at?
Old Apr 3, 2005 | 12:00 PM
Turbo13's Avatar
And in case you were really curious, it was an AWD Dynojet at MAC Autosports in Parker Colorado. And I was dynoflashed before as well.
Old Apr 3, 2005 | 01:01 PM
Dropspeed's Avatar
I launched mine today fo the first time, (860 miles)
3k = bog
4K = bog
5K Rev limiter, Still bog a little and took off,
I'm guessing 6k is the sweet spot???? or I just need more power to get the wheels to spin a bit more
Pete,
Old Apr 3, 2005 | 01:03 PM
lil'evil_evo's Avatar
Don't launch that much, but when I do it's around 5k.
Old Apr 3, 2005 | 01:04 PM
3k = bog
4K = bog
Pete,
maybe after you get the rev limiter removed
Old Apr 3, 2005 | 01:21 PM
evolved04's Avatar
i have had good experience with a 4.5 k launch a few times on the street. hasnt seen a drag strip yet, so i have some kinks in the technique to work out.
Old Apr 3, 2005 | 01:48 PM
rburris28's Avatar
Stock, the best I've found is to bounce the throttle between 5,000 and 5,500 a few times, the QUICKLY release (don't dump) the clutch as it falls to 5,000, and as the clutch releases floor it. It takes practice to get the clutch out and the throttle buried at the same time, but it's sweet when you get it right. No bogging, no clutch smell, no wheel hop (the tires just chirp) and it does not feel like it's a shock to the driveline. I wouldn't do this on uneven pavement or over bumps, though.
Quickly letting out the clutch at 3,500 while flooring the throttle works as well, with a slight bog, but not much difference in 0-60 times on my accelerometer. Probably easier on the clutch and transmission, and not enough difference in acceleration to matter except when you need that 0.1 sec advantage.
Old Apr 3, 2005 | 01:50 PM
BlkEvo8AMS's Avatar
nothing better than a 7 grand launch, anyhting lower, is poo poo
Old Apr 3, 2005 | 01:53 PM
evo81's Avatar
5500,if i want a tenth more off my time,than 6500
Old Apr 3, 2005 | 01:57 PM
Jakeg97's Avatar
3k = bog
4K = bog
Pete,
you need more power
UT_Evo's Avatar
1-2k
Old Apr 3, 2005 | 02:12 PM
i "launch" at 1000rpm every time i've raced and i beat em all so far... too paranoid after i replaced my clutch MYSELF and installed new transfer case MYSELF. So you konw how that must feel to an owner. Basically, i take off normal as if i were just driving to work and floor it and let the turbo and my shifting do the work
