Car shakes when A/C button turned on...
Old Apr 7, 2005 | 10:33 PM
heSOshAdy's Avatar
Recently I am experiencing the car starting to vibrate hard and even hearing knocks around the engine bay after I turn on the A/C button. Anyone around here had this problem before or know what's causing it? Or perhaps I should just take it to the dealership? Thanks.
Old Apr 7, 2005 | 11:34 PM
trinydex's Avatar
uhm... you might fix this by getting a grounding kit... at least it made my ac run better... i wanna say it's normal but knocking isn't ever a good thing.
Old Apr 8, 2005 | 05:48 AM
NOVA EVO's Avatar
Yeah...the engine lugs a bit at idle with the A/C on...it's normal...you can try a grounding kit, though...
Old Apr 8, 2005 | 05:55 AM
sabastian458's Avatar
take it to the dealer, that way if it is making an abnormal noise they can tell you what really going on. the ac will make a clicking noise but all ac systems do, the vibration i would be worried about
Old Apr 8, 2005 | 05:57 AM
VTECH8TR's Avatar
This is not normal. Take it to the dealer and have them look at it.
Old Apr 8, 2005 | 06:29 AM
Fabolusiconz's Avatar
I agree with the majority hard shaking/vibration/knocking around in the engine is bad. But if it is just a little rattle/engine lug mine does the same thing and I have not had a problem with it at all. I would only take it to the dealer if you think it is major.
Old Apr 8, 2005 | 06:41 AM
MIevo8MR's Avatar
Might be a bad a/c compressor. Take it to the dealer and they'll probably replace it.
Old Apr 8, 2005 | 06:54 AM
NOVA EVO's Avatar
Some lugging is normal...but if he's getting really bad knocking, then that's another thing entirely...
Old Apr 8, 2005 | 07:02 AM
NocturnalEVO's Avatar
my car does the exact same thing!! However i haven't tried it with turning on the A/C. But it happens when i turn on the defogger for the windows. If you find out whats wrong with it, let us know.
Old Apr 8, 2005 | 07:08 AM
NOVA EVO's Avatar
The A/C compressor runs when you use the defogger.
Old Apr 8, 2005 | 07:23 AM
MIevo8MR's Avatar
The a/c compressor doesn't run unless the a/c button is turned on. The a/c button tells the PCM to turn the compressor on, so without the PCM request the compressor is not on. If the car vibrates and knocks only when you turn the a/c button on, is safe to say that the two are related.
Old Apr 8, 2005 | 09:24 AM
heSOshAdy's Avatar
Thanks for the replies, I am pretty sure this isn't normal because it started doing this just recently. Again, the shaking/vibration and the engine noise doesn't seem to start untill I hit the A/C button on. I will take my car to the dealership and see what they tell me.. and let you all know. Thanks again.
Richard
Old Apr 8, 2005 | 09:41 AM
Ev0 1's Avatar
Richard
Richard you need to come to the meets this sunday and next sunday. It's only started to do that because it just started getting hot! lol
neonglh
Sep 3, 2021 10:29 PM
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
eTiLiKo
May 23, 2012 05:45 AM
nosreme722
Feb 8, 2012 10:57 PM
cdavy
Apr 19, 2006 05:51 PM
