A/C always on
Old Dec 17, 2011 | 08:48 PM
nosreme722's Avatar
A/C always on
When ever the air is on, on any setting the AC is on. Obviously pressing the AC button button does nothing. The air works fine and its even almost neutral temp if turn the temp knob to all the way hot.
Havent looked at anything yet but.. any ideas?
Old Dec 18, 2011 | 08:29 PM
nosreme722's Avatar
Anyone? I may just replace the head unit.. but im not even sure what specifically that is
Old Dec 18, 2011 | 10:02 PM
CrAnSwIcK's Avatar
take the cover off, and see if the button/switch isn't just stuck...
Old Jan 24, 2012 | 12:56 PM
MotownLancer's Avatar
I had an issue with mine where the heater knob broke off and it would only put out luke warm air. What happens is the stock gear setup they have gets worn and stuck in one position and you can actually manuall adjust the heat of the air but turning the gear under the dash. Refer to this video for help finding where it is.
http://www.youtube.com/watch?v=uaX-YASmgp8
Hope this helps!
Old Jan 24, 2012 | 07:08 PM
nosreme722's Avatar
Hope this helps!
thats not quite it.. lol i already fixed that problem! my problem is the acutally Electronic A/C button. I took everything apart and its definitely not mechanical. I think i just need a new A/C control panel, the entire electric panel, or the only 3 actual buttons.
Although i havent checked the fuses yet so.. ill do that too.
I'll probably pick one off a salvaged lancer and get it real cheap
Old Feb 5, 2012 | 02:58 PM
nosreme722's Avatar
Hope this helps!
Guess who's a turd.. yes, mua. haha so my A/C did always stay on but i got another A/C unit and now i have the same problem you referred to in the video. The knob is broken off and the lever under the steering wheel is very hard to turn..
Dont know what to do but ill figure it out
Old Feb 7, 2012 | 04:33 PM
nosreme722's Avatar
Well now i cant figure out why the temp control mechanism MotownLancer had in the video is so tight. I can barely move it reaching under there doing it with my hand
Old Feb 7, 2012 | 04:35 PM
CrAnSwIcK's Avatar
known issue for lancers and evo's from 2002-2006
Old Feb 8, 2012 | 10:59 AM
nosreme722's Avatar
Sooooo is there a known solution?
Old Feb 8, 2012 | 10:57 PM
CrAnSwIcK's Avatar
Yes...as a matter of fact there is! Whether you have the time or patience to repair the worst case scenario yourself, is up to you...
https://www.evolutionm.net/forums/ev...ega-guide.html
clanzkiller
Mar 16, 2017 07:13 AM
josephatgts
Lancer Troubleshooting
Sep 18, 2016 02:23 PM
HKSevolutionNYC
Feb 2, 2016 10:27 AM
eTiLiKo
May 23, 2012 05:45 AM
ultraflip
41
Jul 22, 2008 06:50 AM
