Handbrake
Old Feb 8, 2012 | 05:26 AM
solbadguy228's Avatar
Handbrake
Hey Guys,
I have this issue with when I park and pull handbrake after in the spot the oil pressure warning flickers and disappears. I am just worried not sure if this is an issue. I drive a 05 lancer es. I had changed oil already 3 weeks ago, so it has oil.
Old Feb 8, 2012 | 10:25 AM
CrAnSwIcK's Avatar
your sure it's the oil light? check oil level and replace the pressure switch...
Old Feb 8, 2012 | 10:39 AM
Vivid Racing's Avatar
It ONLY happens when you put the handbrake up?
Does it happen when you're parked on a level surface? What about on an incline?
Old Feb 8, 2012 | 11:17 AM
its the oil pressure light thing that looks like pan with liquid coming out, I have parked at area that is most part straight it only happens when I apply the hand brake. It did happen at home too when I park my area is on a downward slope, and when i pull hand brake and it did the same thing oil light is not on but it faintly blinks/flickers and than disappear.
Old Feb 8, 2012 | 10:55 PM
CrAnSwIcK's Avatar
are you sure it doesn't happen when you're driving? It's probably a bum pressure switch...they are like $10 and pretty easy to replace..
Old Feb 9, 2012 | 02:15 AM
I am sure, when I am driving everything is fine, till I park downhill slope, I will try to stop the car completely before I pull hand brake and see if this makes a difference.
Old Feb 9, 2012 | 03:48 AM
CrAnSwIcK's Avatar
you brake abruptly with the hand brake on a slope and that's when it happens?...your oil might just be low...double check the stick on level ground...
Old Feb 9, 2012 | 05:17 AM
It does not do it anymore for now, when I take out dipstick and reinsert it it won't show up anymore weird.
ksattic
27
Dec 7, 2005 10:14 AM
EvoRs
Mar 25, 2004 10:22 PM
Rvl
Nov 27, 2003 05:07 AM
RallyBrit
Apr 23, 2003 01:09 PM
rhyzin
Lancer Troubleshooting
Feb 25, 2003 12:28 AM
