View Poll Results: Which is the best cam setup?
GSC 272 intake / 264 exhaust
40.00%
GSC 264 intake / 272 exhaust
60.00%
Voters: 10. You may not vote on this poll
Need honest input...cam setup
Old Apr 13, 2005 | 08:52 PM
AutoEuphoria's Avatar
I've been seeing a lot about different cam setups on here - the only problem is, everyone LOVES each setup lol. So I'm asking which is the best setup (of the two I posted). Please vote, and if you would please also explain your choice and the reasoning behind it. Also note that this would be used with stock cam gears and a dynoflash mail-in.
Thank you so much for your input!
Tyler
IF A MOD SEES THIS: please add: GSC 272/272 option onto poll. Thanks
Old Apr 13, 2005 | 08:55 PM
Damn...I think I meant to post this in the Engine section Well, maybe it'll get more views here
Old Apr 13, 2005 | 08:57 PM
KILTERMAN's Avatar
I voted but know nothing and have no reasoning behind my vote ha
Old Apr 13, 2005 | 08:59 PM
healthynine's Avatar
I voted for the 272/262 setup. If you search for these setups, GSC claims this setup will allow more power, and the 262 exhaust cam isn't necessary unless you plan on later upgrading the turbo. Personally, I am soon ordering the 272in/262ex, and they seem to have amazing power gains. Hope that helps some.
Old Apr 13, 2005 | 09:19 PM
Yeah I was hearing some good stuff about the 272 in/264 ex. setup, but couldn't believe it because I ALWAYS thought having more cam lift in the exhaust side is the better setup.
Old Apr 13, 2005 | 09:28 PM
umiami80's Avatar
I never understood the 272 intake and 264 exhaust setup. If anything you want a larger duration for the exhaust as this is where your power is made. The only reason you want a smaller duration up front is to give you a better idle but will sacrifice some WHP and topend.
If ANYTHING get 264 intake and 272 exhaust. The more hot exhaust gases that get expelled the cooler things are and more cool air to get sucked in.
I got sraight 272's, get them.
Did you need to run different cam gears with the 272s, or will the car run fine without them? I don't mind a lopey idle, but I don't want it to stall.
Old Apr 13, 2005 | 10:15 PM
umiami80's Avatar
Different tuners say different things
Both Turbo Trixx and Buschur I BELIEVE do not use gears, while others do. I don't use them nor will I ever.
straight 272's and a proper tune will get you a GREAT idle and GREAT power. 272's will LOWER your EGT's and add massive topend ability. If you uses a 264 with any upgraded turbo you may be losing some whp.
Old Apr 13, 2005 | 10:24 PM
I think you've finally answered my questions well...just one more - You use HKS or GSC?
CNano8
Feb 8, 2009 12:32 PM
Johnboy1065
17
Nov 19, 2007 11:11 PM
ModifiedMR
33
Oct 11, 2006 04:59 PM
EVOlutionary
13
Sep 13, 2006 07:17 PM
The Emperor
Aug 12, 2004 08:17 AM
