Difference between Dynojet dynos?
Old May 9, 2005 | 07:58 AM
steinvb12's Avatar
Question Difference between Dynojet dynos?
Just wondering if there can be much of a difference from one Dynojet dyno to another? I recently had my car on a dynojet dyno and produced 302 whp with a 3rd gear pull. Then this past weekend I took it to another shop with a Dynojet and it produced 282 whp with a 4th gear pull. Right after we did a 3rd gear pull and it was about 290 whp. But that would indicate it is still reading 10 whp low. Why would this happen??
The only difference between the two times is that instead of stright 93 octane, I used a 93 and 100 octane mix (half and half) and turned the boost up from 22 psi to 23 psi. And it seems the 2nd time was still lower than my original dyno reading. I would think if anything it would be higher, especially since they are both Dynojets.
My mods are:
Utec Piggyback ECU
HKS Cat-back Exhaust
HKS 264 cams
HKS Cam Gears
Greddy EBC
Walbro Fuel Pump
1st time: 302 whp
3rd gear
93 octane
22 psi
2nd time: 282 whp
4th gear
23 psi
Anyone have any thoughts? Or is it typical for all dynos to read differently even if they are the same type?
steinvb12
Old May 9, 2005 | 08:40 AM
GTVEVO's Avatar
Basically no dyno reads the same, since you were at two difference shops they probably had the dyno software setup alittle different compaired to the other. There are factors day to day that impact the reading even if they are adjusted the same also. Honestly no dyno will read exactly the same, this is why you usually find one and try to stick with it and do testing before the mod then directly after so you can see a true difference in gain.
Dynos are fun but on the other hand if you switch around they can be frustrating. I wouldn't worry about it to much.
Old May 9, 2005 | 08:47 AM
steinvb12's Avatar
Thanks for the input. I wasn't too worried, but I'd just thought I would get another opinion. They had a stock SIT come too, and it put down 240 whp, which I would think it fairly accurate. However, the 4th gear for a 6 speed is difference than 4th for a 5 speed...
Also, what is the difference between doing a pull in 3rd vs 4th. Shouldn't the dyno also have to adjust for that?
Old May 9, 2005 | 10:08 AM
GTVEVO's Avatar
When you test on a dyno to get the best accurate results I believe you want to be as close as a 1/1 ratio as possible in the drivetrain. I believe 3rd is a little low and 4th is alittle tall so opinions vary with different dyno operators. I don't know the exact pieces of it but this is what I was explained so others might be able to answer that question alittle more indepth for you.
Old May 9, 2005 | 11:05 AM
Evo348's Avatar
For every car before it gets on the dyno it has to be at full working temperature( water temp gauge has to be in the middle) and since the evo VIII gsr is a 5 speed, then the most accurate gear would be third. Unlike the MR version that's a 6 speed then the most accurate would be fourth, just like in skylines and supras. A dynojet would be the most accurate to really measure you WHP, try to stick away from mustang dynos since they dont read awd. Its a dissapointment to just guess your whp than just dyno it right? well take care bro i hope this helped you.
Old May 9, 2005 | 11:07 AM
BadazzCR's Avatar
There is no way to manipulate the Dynojet software to get higher readings. So as long as you dyno'd with the SAE correction both times on both dynojets there should be less than a 2% difference.
Old May 10, 2005 | 10:35 AM
steinvb12's Avatar
What should the SAE correction be? I believe one dyno map had .99 and the other "1.00 uncorrected". This can't be much of a difference, can it?
Freddy302
Apr 21, 2017 12:32 PM
Dynotech Tuning
Evo X Dyno Results
50
Feb 27, 2012 08:13 PM
scorke
199
Jun 17, 2009 02:36 PM
David Buschur
18
Jan 6, 2009 09:19 PM
kouzman
35
Jan 15, 2007 10:59 PM
