ams 1200 hp fuel system worth it?
Old May 13, 2005 | 05:45 PM
evo8silver's Avatar
Question ams 1200 hp fuel system worth it?
Just wondering if anyone has tried or heard about the ams fuel system upgrade? TIA
Old May 13, 2005 | 05:58 PM
BlackThorN's Avatar
link something too it and you'll get more responses
good luck
Old May 13, 2005 | 06:23 PM
badlooser's Avatar
If you are making between 550-1000 hp yes it will allow you to make the big HP .The stock fuel system is limited to about 550 whp+ or - depending on you set up.
Old May 13, 2005 | 06:35 PM
evo8silver's Avatar
okay, well would you guys think im going to need to get the ams fuel upgrade because in a couple of months im getting a 2.3 or 2.4 stroker kit, big turbo, and head work done to my car. I was wondering if i would need the fuel upgrade or just get a walbro fuel pump, and 4 700 injectors.
Because the fuel pump and injectors are sooo much cheaper then the fuel upgrade.. what exactly does the kit come with cus i dont understand it. Well sorry for being kinda ignorant. Well ur help would be great.
heres the link:
http://www.automotosports.com/evo_fuel.asp
Old May 13, 2005 | 06:39 PM
badlooser's Avatar
from what I have heard the stock fuel system with a walbro and big injectors is limited to 600whp so if you want more you will have to upgrade to some fuel system that will feed more fuel into your motor or you will be limited to that hp...
Old May 13, 2005 | 06:43 PM
evo8silver's Avatar
okay thanks sor far... but isnt the evo only really capable of around 650 to 700 whp max? Also "badlooser" would u happen to know what other companies offer fuel system upgrades? thanks
Old May 13, 2005 | 06:47 PM
Evolving-04's Avatar
you will def need something past the 500-550 mark and bigger injectors than 700's and with the AMS kit you get a bigger fuel rail, fuel pres. regulator,stainless fuel lines, 2 upgraded walbros, and you will never have to worry about running out of fuel and toasting your new engine running lean.
Old May 13, 2005 | 06:50 PM
I think very soon you will see more HP than that on alot of evo's.
Old May 13, 2005 | 06:58 PM
badlooser's Avatar
RNR racing just posted they made like 731whp on a gt40 turbo and they are going bigger to make more HP. I do not any other system that uses the stock fuel tank but just like it has been said you can upgrade all the fuel components and run 2 pumps with some fabrication.
Old May 13, 2005 | 07:00 PM
en1gma19's Avatar
Yeah, RnR already made 731 with their 2.4 block and AMS isn't done with their "new" setup. It should make some very very nice numbers.
Old May 13, 2005 | 07:05 PM
evo8silver's Avatar
yep okay thanks for the info guys! really helpful. Well so any suggestions of whats the BEST thing i can do to upgrade my fuel system?
Old May 13, 2005 | 09:03 PM
BlackThorN's Avatar
how much $$$ are you trying to spend, there's tons of solutions to fueling but it depends on your overall budget
Old May 13, 2005 | 10:36 PM
evo8silver's Avatar
well i dont want to spend a lot on the fueling solutions of my car. Reasonable and as long as its worth it.
Old May 13, 2005 | 11:06 PM
plokivos's Avatar
fuel good, if air induction matches along with exhaust circulation matches.
Old May 13, 2005 | 11:17 PM
evo8silver's Avatar
I dont understand sorry its kinda late now. so it could be me.
Skidonner90
21
Oct 1, 2016 12:23 AM
rawkus
Aug 7, 2009 08:47 AM
Teal2nnr
19
Jul 18, 2009 10:34 PM
The Driver
E85 / Ethanol
11
Aug 20, 2008 03:59 PM
newbiewonkenobe
Lancer Engine Tech
Apr 5, 2006 05:23 AM
