How to verify if I have a Walbro 255?
Old May 16, 2005 | 08:30 AM
woodc's Avatar
I just bought a 2003 that the PO said he put a Walbro 255 in. He has the stock fuel pump and I have no reason to doubt him...however when I contacted the dealer they show replacing the fuel pump under warranty *after* he installed the 255. He says after the install the gas gauge quit working and they replaced the fuel pump housing or something like that <shrug>
I am about to send my ECU off for a flash and want to make sure I actually have the Walbro unit still. Can I tell by looking at the pump if I pull it out which it is?
Old May 16, 2005 | 04:29 PM
Jamie@WORKS's Avatar
It should be stamped with the Walbro insignia as well as the part number GSS317 or GSS342.
Old May 16, 2005 | 04:43 PM
mike69's Avatar
The noise is also very noticable.
Old May 16, 2005 | 05:00 PM
ct9a gsr's Avatar
Pull out the pump housing and check the pump itself. He probably bent the black arm on the pump housing while installing the pump, which messes up how your fuel gauge reads.
Old May 16, 2005 | 05:14 PM
woodc's Avatar
I am glad to hear they are clearly marked.....I will pull it and see :-)
Thanks all
Old May 17, 2005 | 05:46 PM
woodc's Avatar
Well, I pulled it out this evening and it says Nippon Denso on it and has some of the same numbers as the stocker so....looks like the dealer *did* replace the Walbro with another factory one <roll eyes>
Old May 17, 2005 | 05:51 PM
justchil's Avatar
lol what a noob (the previous owner)
Are there signs of any other mods?
Old May 17, 2005 | 05:57 PM
Mivo's Avatar
ya thats is a very easy way to tell.
Old May 17, 2005 | 06:50 PM
plokivos's Avatar
noise isn't always something you could count on.
I installed mine, didn't make any sound. Sounds like stocker.
Old May 17, 2005 | 08:41 PM
JSYEVO's Avatar
what kind of noise does it make?
Old May 17, 2005 | 08:48 PM
Warrtalon's Avatar
It whines really loudly, audible at all times in or out of the car.
Plokivos claims not to have heard a sound, but I've never heard of this or experienced it in person. It is a very noticeable whine, and if I don't hear it when I install mine, I will probably re-install it until it does, because that means something is probably wrong.
Old May 17, 2005 | 08:51 PM
plokivos's Avatar
nothing is wrong. everything works good.
maybe you installed it wrong, that's why it whines. Ever thought about that?
Old May 17, 2005 | 08:57 PM
Warrtalon's Avatar
Uh, no, because everyone else in the world who installs one hears the whine, and some get so annoyed that they take it out. You do know that, right?
Old May 17, 2005 | 09:01 PM
Ztypestock8's Avatar
I have one and its not too bad. But hey, you got a walbro 255 fuel pump so what if its noisy. Get some cams and you'll really feel a difference in power and the way it sounds. Its all a part of modding up your ride.
Old May 17, 2005 | 09:19 PM
plokivos's Avatar
you obviously didn't talk to people who don't hear sounds with theirs. Or I guess you know everybody in the world.
