Intercooler water spray
Old May 25, 2005 | 01:14 AM
turtlelancer's Avatar
it was for teh acd i heard
Old May 25, 2005 | 04:16 AM
wheming's Avatar
Originally Posted by Mivo
it just helps keep your car that much kooler... a squirt lol but it doest help in dry high humidty places.
You mean dry hight temp places, right?
You can't have dry high humidity...
Old May 25, 2005 | 04:24 AM
wheming's Avatar
It is functional, if only marginal.
At least in theory it could really be a benefit under certain conditions.
Not all geographic areas will benefit the same obviously since it is operating on the evaporation of the fluid in the container.
i don't know what the factory gives you, but i believe regular windshield fluid (that has a bit of methanol in it) would work good.
dip your hand in room temperature water, then start fanning it around. feels alot colder than the other dry hand when you fan it.
Hehe, now try Isopropyl Alcohol... brrr
Old May 25, 2005 | 05:00 AM
Scooter's Avatar
I tested it in August of 03 when I dyno'd my car for the first time. I think the sprayer gave me like 9 HP... of course it was 98 degrees out with 110% humidity (OK well it FELT like 110% humidity) So it does work, but it is a marginal power boost... I'll see if I can find the Dyno Sheets and post them...
Old May 25, 2005 | 07:01 AM
white05evoVIII's Avatar
sorry to tread on your thread but i wanted to know if the 05's came with this. i have an 05 and i don't think i have it. there is no switch for it that i have found.
Old May 25, 2005 | 07:02 AM
my bad found my answer in same thread
Old May 25, 2005 | 07:43 AM
fsugatorbait's Avatar
Just for ****s and giggles, is there a way to incoporate this into the 05's?
Old May 25, 2005 | 08:27 AM
Scooter's Avatar
You could probably make one yourself... Sport Compact Car had an article on how to make one yourself for like $12 in parts from a hardware store... I'll look for the article.
Old May 25, 2005 | 08:46 AM
Nice. I appreciate the effort. It'll make for a nice weekend project.
Old May 25, 2005 | 08:53 AM
SterlingEvo's Avatar
yeah, When I last dynoed I sat in the car and held down the button. Who knows if it made a difference, because the Mustang Dyno I was on varied by like 10hp between 4 runs... I often leave it on auto on hot days, but the tank never seems to deplete...
Old May 25, 2005 | 09:02 AM
WildRice's Avatar
The temps here in N Ca get into the 110s. I have only smelled the coolant from the sprayer one time. I was drivng fast up a steep three mile grade n 100+ temps. If I had to guess I would say it is only a mild safety feature at best. If you never have to add fluid to the tank that tells you how much you need it. I have run 50/50 water alcohol with dry ice, washer fluid, and plain water. It seems like just a waste of space. You can only carrry a gallon of water so even if you did get 10HP from it how much could you really use it in manual mode. It empties in less than two minutes (try two 60 second runs). Mitsu should have given us a better BOV or decent sound system speakers instead.
Old May 25, 2005 | 09:41 AM
grcygetr's Avatar
I forget mine's even there. As far as the auto-mode, how is that supposed to work? Does it spray @ WOT only?
Overall, I think it's useless. I think I'll bend the nozzles to point out and spray people....
Old May 25, 2005 | 10:14 AM
woodc's Avatar
For you guys who have removed it: How much does the entire system weigh? Does anyone know?
Old May 25, 2005 | 11:00 AM
I've always wondered that. Or if it's at a certain boost. Who the hell knows
Old May 25, 2005 | 04:52 PM
killr evo 8's Avatar
I agree. Does anyone really use the water spray at all? I think I've used it once but it didn't really seem to help. I've heard (and this is only a rumor) that someone actually dynoed with and without the spray and it gave like 2 hp. Anyone else have any experience?
