CV Joint blown?
Old May 24, 2005 | 08:41 PM
escoson's Avatar
CV Joint blown?
my problem is i think the CV Joint on the front driverside axle is shot. When i make left turns regardless of acceleration/braking it clicks. it also clicks while going over bump parts of road/parking lots and when im slowing down below 15mph i notice it while braking slowly. any insite on this is much appreciated.
- tore
Old May 25, 2005 | 03:10 AM
hawaiievo's Avatar
yea the clicking noise is from the cv joint . also look under your car and at the joint and you will be able to see the boot broken. there will also probally be alot of grease on it. hope it helps. my old lady had the same clicking and it was the cv boots.
Old May 25, 2005 | 07:30 AM
HwangTKD's Avatar
I had the same problem, turned out to be a blown strut.
Check out my thread ..... my 75,000 review
Old May 25, 2005 | 07:35 AM
PA-silver03evo's Avatar
When the outer cv joint goes bad it clicks while turning. When the inner cv joint goes bad, you usually hear noise from it when accelerating. Like was mentioned, look for grease because a torn boot where the grease leaked out is usually the reason for the joints going up.
Curt@MrLed's Avatar
Former Vendor
most likely its your cv.. turn your whell too the side that clicks, accelerate, and the clicking gets worse its a cv joint.. its a easy job too replace it..
Old May 25, 2005 | 08:01 AM
zstryder's Avatar
I'm having the same problem, I just noticed it today, too. At speeds of < 15mph when going over bumps I can hear super loud clunking noises. I didn't notice it as much while turning, though. If I do have a blown CV joint, I wonder if this has anything to do with the fact that my front camber was way out of spec when I got my last alignment (I talked about that in this thread here https://www.evolutionm.net/forums/sh...d.php?t=137835).
Old May 25, 2005 | 11:39 AM
JaReDbOy's Avatar
omg! i think i have the same problem- 45k on the evo... hear a weird sound while making slow left turns.. dont know if i would describe it as a click.. but some kind of noise.
what the hell.. it looks like this is happening to alot of evo's.. is this covered under drivetrain warranty at all?
if not is it costly to get repaired/replaced?
or someone said its easy to do yourself.. how much are replacement parts?
Old May 25, 2005 | 03:10 PM
escoson's Avatar
thanks for all the replies it is the cv joint. ive searched online for parts but have had no luck yet. anybody know of any place online to order replacement parts?
Old May 26, 2005 | 09:59 AM
Curt@MrLed's Avatar
Former Vendor
here is the easy way to keep you joints in good health.. DO NOT turn the wheel to lock and gas on it.. this is the biggest failure of cv joints.. The second is people not replacing the dust boot.. if you see a crack replace it.. i have had cars with 200,000 mi and still useing the origanal cv joints.. its just simple maint. to keep them in good health..
Old May 26, 2005 | 08:40 PM
Curt@MrLed's Avatar
Former Vendor
bump for good info..
Old Apr 28, 2010 | 08:15 AM
B-rent's Avatar
40k on my baby and the passenger inner cv boot just tore anybody know of a good DIY thread to replace it?
Old Sep 7, 2011 | 10:00 PM
marcusE's Avatar
Hey, Both of my outer CV shaft boots are cracked and are gushing grease.. I need to replace just the CV shaft or should I replace the entire axles? Where to get the parts as well BUMP please.
Old Sep 8, 2011 | 06:04 AM
coolguyuno1's Avatar
Sounds like a balljoint, not the CV shaft.
Old Sep 8, 2011 | 06:15 AM
barneyb's Avatar
Agree, I've never replaced an axle. I've replaced boots on five ocassion that I remember (this on three different cars). Every time I'm under for an oil change I check boots.
Old Sep 8, 2011 | 04:27 PM
marcusE's Avatar
My outer boots are torn.. I'm going to just replace both CV shafts although they arent making clunking or clicking noises while turning...
powerstroke
Feb 9, 2017 11:59 AM
powerstroke
Jan 30, 2017 07:38 AM
jingalalahoe
Sep 9, 2016 12:44 AM
ezzey
Dec 28, 2015 05:36 PM
trickytrick
Jan 22, 2014 06:07 AM
