Ground kit/starting problems
Old May 24, 2005 | 09:20 PM
RyanM's Avatar
Car won't start after installing Hyper Ground kit. I double checked all connections, should be much better. Instead, car turns over, all eletrical accessories function, but car will not start.
It acts like it wants too, but doesn't fire off.
Old May 25, 2005 | 04:55 AM
mump's Avatar
check the fuses in the engine bay. sounds like you might of blow one. same thing happened to me install a turbo timer - everything worked, car just didn't fire.
Old May 26, 2005 | 06:28 AM
RyanM's Avatar
Checked every fuse in the engine bay, all were intact. Car almost sounds like it has a vacuum issue but not sure about that. I didn't touch anything with the induction. It sounds like its close to turning over but just doesn't get there. Is it possible the the common grounding is causing that issue? I am going to take the kit off tonight and see what happens. BTW, this is my Girlfriend's car. When I put Hyperground kit on my Evo, I had no problems whatsoever. Kinda strange. I didn't do anything different. I've had them side by side for hours and I did it exactly the same.
Chasis ground problem on her car? Difference between 04 and 05? (Her's is the 05)
Old May 26, 2005 | 08:14 AM
RalliArtEvoVIII's Avatar
did u d/c while installing the ground kit? possibly relay switch or something?
snazzyseth
Mar 19, 2015 06:08 AM
henry22
Jan 25, 2014 08:44 PM
bigben
May 17, 2012 03:39 PM
BCOZEVO
Mar 3, 2008 08:09 AM
SIMSSEGA
Apr 7, 2004 06:38 PM
