Car took a shi.t on me again.
YO YO CHECK all your fuses. Check the ECU fuse.... I had a S-AFC and I had it wired a little funny. It blew the fuse. Also Check to see if your Fuel Pump went out way to do this is basically turn key to on postion and listen for a TINY wine noise. That would be your pump.
ur right about the service rep, his a fu.cking idiot. Thats York PA for anyone in the area he in the master of all tools, anyways can't believe you got rid of your evo, if i get rid of my evo i'm getting away from mitsubishi, i've had nothing but problems with them since i had one
Originally Posted by 04Evo8RS
alright keep me informed
Just incase you didnt know or see i got rid of my evo and got a endeavor...they voided my warranty from having my turbo back .....and i was having warped brakes and TC problems...so i said screw them and traded the car in....the service departments are awesome but that main guy the service rep he sucks and dont know jack about cars
yeh, it could be your ECU fuse going out due to humidity or the moisture.
But also, this happened to me few times.
It maybe the cam crank sensor and angle sensor that's wet, automatically shutting the car down.
Most of the times, it'll happen in the rain.
did it throw a code?
thx man, you were right it was the ECM fuse, since it reset the ECU there are no codes and the tech didn't know why this happened so i'm keeping a few extra fuses in my car now.
Originally Posted by smokedmustang
if you mention the car dies when a Harley is next to you, or when thunder hits. try Dont believe it? have a friend line up next to you,on a loud Harley and rev it up! and your car will Die! enough said
