Help! Why is my oil light coming on?
Old Jun 7, 2005 | 03:58 AM
Shinka's Avatar
Unhappy Help! Why is my oil light coming on?
Hey guys
I have seen a few posts on other message boards but I want some opinions from EVO experts.
I was in town today in my 03 Evo with 4,400 miles. My oil light came on when I came to a stop. If I reved the engine past 1,000 rpms then it would go off. I stopped and checked the oil and it was fine.
Since it was mentioned in other post I will pass on that it was 95 degrees today and I had the air on full.
Should I be worried about this or is it just a bad switch? What should I do to resolve the problem?
thanks
Pete
2003 Evo VIII
2004 Yukon Denali
Old Jun 7, 2005 | 04:54 AM
Shawk's Avatar
Well to be honest, i havnt got a clue either
Old Jun 7, 2005 | 05:09 AM
TexasRS's Avatar
No clue...sorry...
Old Jun 7, 2005 | 05:16 AM
Jadiem's Avatar
it's called crank walk... thats normal
Old Jun 7, 2005 | 05:49 AM
an0ther's Avatar
did you check your oil? 4g63's are known for burning a little oil, especially at low miles.
Old Jun 7, 2005 | 06:02 AM
PVD04's Avatar
It could be a problem with oil pressure, not oil level. If your car is stock, you should be able to get it checked out for free under warranty.
-Paul
Old Jun 7, 2005 | 06:03 AM
redevo561's Avatar
-Paul
+1
Old Jun 7, 2005 | 09:27 AM
webguy330i's Avatar
Originally Posted by redevo561
+1
+2 * infinity
Your car is brand new; stock I presume. First place to stop would be the dealership, sounds like a pressure problem. If the light came on and stayed on despite your driving, then I'd go with oil volume (or lack thereof) as the problem.
Old Jun 7, 2005 | 09:35 AM
grcygetr's Avatar
yep, gotta be the pressure. At low RPM it's not pumping fast enought to raise the pressure. Give it a bit of gas and the pressure increases, and turns the light off.
Check your dipstick, make sure there's enough oil. Drive to dealership and make them check it out..
Old Jun 7, 2005 | 09:37 AM
webguy330i's Avatar
Also I wouldn't really let this go for too long. Imagine if when sitting down, your heart slowed so much that you'd start seeing spots and such... not good!
Old Jun 7, 2005 | 11:10 AM
Shinka's Avatar
I am taking it to the dealer tomorrow AM
The car only has 4,400 miles. Its had 2 oil changes already at the dealer. I hope its nothing major. Since I have only had this car 1 week this is kind of a bummer.
I do hope my first vist to the deal is not like Sterling BMW. Anyone have any experience with Sheehy Mitsubishi in Manassas, VA?
thanks
Pete
Old Jun 12, 2005 | 09:50 AM
JOHNNY EVO's Avatar
Hey guys, I'm getting this same problem. The oil light comes on below 1,000 rpms. Does anyone have first hand experience on what is wrong when it does this? Mine just started to this this on the way home last night.
Old Jun 12, 2005 | 09:54 AM
Sailorgoon's Avatar
Probably just a broken oil sender. Had a couple of them on my OZ. If you're under warranty, go take it in. Most dealers with a service bay stock the senders and can replace them in less than an hour.
Old Jun 12, 2005 | 10:13 AM
apexernsx's Avatar
Does it do it cold?
Old Jun 12, 2005 | 10:27 AM
si_eater's Avatar
Originally Posted by Shinka
Hey guys
thanks
Pete
2003 Evo VIII
2004 Yukon Denali
check oil level, if its ok then you may have a pressure problem, take it to the dealer, or just a faulty sender
off topic:where in warrenton do you live i live in warrenton also and i also have a rally red
