Blowin Smoke!!!!
Originally Posted by 4rcd6
Ok so I've noticed a pattern here.. let me see if you think its my deal or not..
This IS NOT Fuel burning out the pipe.. its oil and thats a for sure thing... when i notice it happens is after i run a few gears in high boost 15+ and I let the gas off.. after a moment.. smoke is shootin out the pipes... it happens for a very short bit and then stops and never does it again until i give it similar symptoms.
Is this blow by oil circulating in back through the intake mani and burnin off?? I DO NOT have a catch can which I need now Im guessing.. and my exhaust NEVER smells like anything but gas fumes.... my oil is at good height on the check stick.. so im not losing any oil.. I may need to take my intake piping off and see if its collecting in the bottom of it but.. just wanting to know if you think its the blow by oil just burnin off.. Thanks
How many miles are on your car ?
Sounds like some blow by or possibly a turbo seal leaking a bit under boost
It is prob nothing to worry about unless the condition worsens
Sounds like a combination of blow by and the the fact that you do not have a cat to catch the unburnt fuel. I noticed a big difference in the smoke from my car when I removed my cat. As far as catch cans go I know someone now makes one that mounts very nicely in the V of the Strut Bar brace. That is the only one that seems to fit nicely into our engine bay. I made my own for $5. Two brass fittings, some scrap metal in the garage and a mig welder. It is nice and small and mounts out of sight behind the battery.
jorge mr
22
Nov 9, 2018 05:05 AM
Force-Fed Performance
Apr 25, 2010 03:29 PM
spoolinEVO8
14
Feb 17, 2007 12:40 PM
