Wat To Put In Ntercooler Spray
Old Jun 28, 2005 | 01:21 AM
evo_lee's Avatar
Exclamation Wat To Put In Ntercooler Spray
Im am wondering which fluid to put in the intercooler sprayer resovoir. WATER or WINSHIELD WASHER FLUID. Pleases reply
Old Jun 28, 2005 | 01:34 AM
FinEVO8's Avatar
You should use windshield washer fluid only when the temperature drops near freezing. Otherwise it's just a waste of money, water will do fine.
Old Jun 28, 2005 | 01:36 AM
evo_lee's Avatar
Thanks Man. You like HOCKEY. I do
Old Jun 28, 2005 | 02:22 AM
Azure's Avatar
Old Jun 28, 2005 | 06:02 AM
PVD04's Avatar
I use washer fluid year round in mine. If you use just tap water, you can get deposit build up in the lines so I would recommend either washer fluid or distilled water.
-Paul
Old Jun 28, 2005 | 06:54 AM
4-BNGR's Avatar
Anybody use RedLine "Water Wetter?"
Old Jun 29, 2005 | 04:06 AM
evo_lee's Avatar
Thanks PVDO4
Old Jun 29, 2005 | 04:09 AM
evo_lee's Avatar
Water Wetter is for your radiator. Mix 40/30/30 or however you want to do it. Doesn't matter by much. 40=antifreeze 30=DI water 30=Redline Water Wetter.
Old Jun 29, 2005 | 04:13 AM
evo_lee's Avatar
To AZURE. #1 Colorado Avalanch Fan dude
Old Jun 29, 2005 | 05:09 PM
BMan's Avatar
Winshield washer juice is best but, the tidy bowl lip sucks.
Old Jun 29, 2005 | 05:26 PM
Turbolover's Avatar
Lightbulb
Distilled water a. wont clog ur nozzles b. has the best hot/cold temperments.
trust me, i used window wiper fluid in my previous 03 and i clogged 2 nozzles! sucked because the dealer wont warranty!
Old Jun 29, 2005 | 05:35 PM
hydrofoam's Avatar
nothing really... the stock ic sprayer is useless
Old Jun 29, 2005 | 06:49 PM
evoPirate's Avatar
its only useless if you dont use the car for what its intended for! I use washer fluid, and I buy the -25 deg stuff or colder if I can find it, has more alcohol in it. Take your car out to an autocross during a hot *** day and try 2 runs with 2 runs without, trust me, there's a difference
Old Jun 29, 2005 | 06:52 PM
plokivos's Avatar
I put Ice in there, big chunks of it.
That usually mixed with alcohol does the trick for a good day or two.
you could put rubbing alcohol, methanol, water, whiskey, vodka. Something that will evaporate fast as a very cold temperature.
Old Jun 29, 2005 | 07:01 PM
WR to the X's Avatar
i second the rubbing alcohol idea, it will evaporate faster than water....
but if you're using ice, use distilled water....
