Front driver side "click" from a stop and under acceleration
Old Jul 2, 2005 | 06:41 PM
Punisherofall's Avatar
I figured someone might be able to help me on this one. My car only clicks one time when taking off fairly aggressively ( above 2500 rpm) and if I am in first or second gear rolling and punch it. Again, it is only one fairly loud click, then I never hear it again until I stop or punch it in a low gear. It also does not seem to make the noise all the time. I don't hear clicking or clunking at all when turning etc.. Seems kind of trivial, but I just wanted some opinions on what it could possibly be. It sounds like it is right behind the drivers side wheel when I hear it ( kind of behind the brakes). I also hear this noise if I am in first at a very slow speed and quickly pulse the gas pedal, it makes a click noise. Well, any help would be appreciated.
Stay safe,
Punisher
Old Jul 2, 2005 | 06:44 PM
EVOMIZ's Avatar
sounds like a motor mount . I had the same problem last week.
rear mount.
Old Jul 2, 2005 | 06:47 PM
thanks, car is a 2003 with only 6100 miles ( not my daily driver) , but still under warranty, so I guess I will bring it in. I could swear it is right behind the driver wheel, but thanks for the quick post
Old Jul 2, 2005 | 06:52 PM
Oh, can you tell me where to look for this motor mount, or can you not see it unless on a lift. Thanks
Old Jul 2, 2005 | 07:12 PM
nnorris7413's Avatar
Do you have an electronic boost controller? Mine clicks, but thats because of the solenoid for the ebc.
Old Jul 2, 2005 | 07:59 PM
no, I don't have an ebc. I do have al's boost controlling flash though. It almost sounds like a metal "ping" if I can describe it better. Again it only happens once then is o.k. until I stop or punch it in first or second. If I take off normal, no ping.... but a fairly agressive take off or low speed throttle jab gets a nice resounding ping, it's more of an annoyance than a problem I hope.
Old Jul 2, 2005 | 08:20 PM
any other ideas on what it might be?
Old Jul 3, 2005 | 11:36 AM
dryad001's Avatar
My guess is the clutch fork, i had a click noise when I took off and still have it with the new clutch. There are 2 springs on either side of the clutch fork and they don't have a seat for them to sit. This is my guess.
Old Oct 9, 2007 | 10:11 PM
MrMejia's Avatar
but how do you explain the noise when coming to a stop? motor mount sounds like a culprit but it could be drivetrain related such as the driveshaft or transaxle?
Old Oct 9, 2007 | 10:18 PM
EiVxO's Avatar
i had a somewhat similar noise and it was actually my intercooler pipe hitting the frame rail
Old Oct 10, 2007 | 02:59 AM
boostless's Avatar
Sounds like suspension. Springs that settle when pulling off. Try twisting them
Old Oct 10, 2007 | 06:50 AM
PeteyTurbo's Avatar
HAd a similar noise, turned out to be the axle nut was not tight enough..
Old Oct 10, 2007 | 12:06 PM
chaz517's Avatar
same issue here, even if i get into the car really quick i hear a click, but every so often when i tak off slowly i hear that click. i hate it
MrAWD
Sep 19, 2016 08:39 AM
kickin wing
11
Dec 13, 2013 01:51 PM
lilmac789
Lancer Engine Management / Tuning Forums
Jan 20, 2011 09:56 PM
evane
Aug 29, 2008 11:32 AM
GuamLancer
14
Jan 30, 2008 01:42 PM
