Keeping engine cool on roadcourse
Old Aug 7, 2005 | 11:14 AM
  #61
meanmud's Avatar
True!!
However, WarmPepsi and I have to deal with 100% RH - I wonder how I could keep my shorts cool too
Old Aug 7, 2005 | 12:36 PM
  #62
GDB's Avatar
GDB
Originally Posted by mdosu
thanks for the tip
What's the size of the T you used to fit in the stock hose?
Jeez I wish I knew The mech did all the work. Sorry I can't help you there.
Old Aug 7, 2005 | 03:21 PM
  #63
trinydex's Avatar
i don't know why you guys are talking about the boiling point of liquids inside the cooling system cuz does it matter? the system is pressurized... that's what keeps it from boiling. nothing else, the temps are already higher than both boiling points before or after antifreeze adding...
Old Aug 7, 2005 | 03:39 PM
  #64
WarmPepsi's Avatar
the system is pressurized, it'll build up pressure until the cap blows.
If you're running over 270 on a course, you're in for some SERIOUS issues. you should be in the low 200's.
And humidity sucks. no doubt about it.
Old Aug 7, 2005 | 04:12 PM
  #65
bdiddy's Avatar
Uhh... I think we covered that a page or two ago, and there is a nifty chart to go with it.
Old Aug 7, 2005 | 04:33 PM
  #66
meanmud's Avatar
Old Aug 7, 2005 | 10:49 PM
  #67
RazorLab's Avatar
Originally Posted by MitsubishZ
true oil temp was up a lil, nothing bad. Brakes felt some fade but mainly it was a feel issue, if I slammed them to the ground they would still stop on a dime.. they just felt a little more squishy than when they're cold.
If your oil temp didn't go much past 70c (normal operating temp) or even 90c, then you were simply not pushing the car very hard at thunderhill in summer heat.
Both events at thunderhill I ran 2 weeks back had me running 120-130c oil temps.
Are you taking the reading off the MR gauge pack oil temp gauge?
154
Aug 16, 2015 12:57 AM
RenleyX
Nov 17, 2014 07:02 PM
turbo50mike
Jul 24, 2013 06:56 PM
1mad evo
Aug 18, 2007 09:18 PM
andenbre
21
Feb 13, 2003 10:57 PM
