Keeping engine cool on roadcourse
Old Jul 26, 2005 | 09:46 AM
Stephen Fisher's Avatar
Anyone have difficulty keeping their engine cool on a roadcourse? How did you correct this issue?
Thanks.
Old Jul 26, 2005 | 09:50 AM
Curt@MrLed's Avatar
Former Vendor
buy a radiator, the t-stat killer, or your basic 2, a t-stat., or a radiator shroud, that bolts to the top of the radiator.. gruppe-s has a good deal right now on one.. thats really all you can do...
Old Jul 26, 2005 | 11:16 AM
Tsurara's Avatar
Big ****ing Koyo radiator and a shroud
Old Jul 26, 2005 | 11:27 AM
speedomodel's Avatar
The Koyo radiator definitely helps. I also use Purple Ice radiator additive and remove the rain guard from the hood vent.
Old Jul 26, 2005 | 01:29 PM
Jakeg97's Avatar
just make sure you replace it before it rains
Old Jul 26, 2005 | 01:32 PM
Affirmative.
Old Jul 26, 2005 | 01:36 PM
rsboy's Avatar
so the radiator shroud really helps? I mean I bought it for that fact and maybe for looks, , also...but I guess I really didnt' think it would help that much. That's great to know.
I'm sure the intercooler spray helps alot also.. but I just kept forgetting to turn it on during my sessions.
Old Jul 26, 2005 | 01:38 PM
Curt@MrLed's Avatar
Former Vendor
i/c sprayer a little.. i wouldnt count on it keeping your car cool though..
Old Jul 26, 2005 | 01:41 PM
nils's Avatar
assuming your stock: the 'BIG' PWR radiator... turn down boost a little.. add Redline Water Wetter... run 'rich'...
you will get better responses if you post this under the 'motorsport' section...
n
Old Jul 26, 2005 | 01:43 PM
Curt@MrLed's Avatar
Former Vendor
but running too rich will be less effienct and cause the car too run hotter..
^^ i suck at spelling
Old Jul 26, 2005 | 01:47 PM
WhosEVO's Avatar
after I install the autometer, i found out the water temp. actually is not that bad at the track....it stay around ~210 most of the time. (90F outside). But the oil temp is another story.......it went as high as ~245f during hot lap and will came back down to 210f on the cool down lap.
Old Jul 26, 2005 | 01:48 PM
Curt@MrLed's Avatar
Former Vendor
as i stated before get the t-stat killer for the oil..
Old Jul 26, 2005 | 01:51 PM
HMSevo8's Avatar
Yeah the oil temp is bothersome in the car. Moreso than the water temp. Plus brake temps get out of control as well. I run the Koyo radiator, no shroud, with a bottle of water wetter. I keep the IC sprayer on manual (although I have Al's alky kit sitting at home, so once that's in, it'll be a different story), and he water temp is fine. I have the factory brake cooling ducts, but nothing in terms of a solution yet for the oil temp. I've tried fabbing some things, but nothing with success yet.
Old Jul 26, 2005 | 01:53 PM
Curt@MrLed's Avatar
Former Vendor
i give up..
Old Jul 26, 2005 | 02:04 PM
machron1's Avatar
Everything on my car as far as cooling is stock and I've never noticed the factory needle climbing up past halfway, so I figured there is nothing wrong with the cooling. I've done quite a few track days like that. I didn't know the oil temp was that high (no oil temp gauge) but I figured it would be alright (factory oil cooler and all) but now maybe I'll look into putting a fan on top of the oil cooler. Thanks for the tip.
