Cams Decision
Old Jul 29, 2005 | 11:47 AM
tbizzy85's Avatar
Does anyone know anything about the Buddy Club cams? They are replicas of HKS but I have never seen or heard of HP gains on these.
Old Jul 29, 2005 | 11:49 AM
speedomodel's Avatar
I'd consider the Tomei Procams because of their higher lift. Wouldn't you know it, there's a groupbuy: https://www.evolutionm.net/forums/sh...d.php?t=147238
Old Jul 29, 2005 | 11:58 AM
TalonRcR's Avatar
Originally Posted by NOLIMITMOTORS
Proven less HP???? How is that if the GSC cams are exact copies of the HKS cams??? same duration, same lift???
If its been proven then someone must have taken a car making exactly xxx whp with gsc 264/264 and then put HKS 264/264 cams in with same tune and the car made less whp?? If this test has been done please show me and I will stand corrected.
Exact profile copy's they used a micro polishing finish on the lobes that reduces friction on the cam lobe. HKS use a bead blasting that leaves a rough finish compared to the GSC. Less friction = more horsepower.
Chris
Old Jul 29, 2005 | 12:02 PM
johnny's Avatar
Registered User
Originally Posted by IDRINKV8
Which cams should i go for to get mid to high end power? I was thinking of getting gsc 272 intake 272 exhaust. People with cams and similar mods as please respond with feedback.
THANKS!!
i also want to buy some cams in the near future but i want them for faster 1/4 mile times which ones should i get 272/272, 272/264, 264/272, 264/264???i got got all the supporting mods just need to save up for the cams.
Old Jul 29, 2005 | 12:03 PM
Chris@nolimitmotors's Avatar
Chris
oooooo, I gotcha, def makes sense, but has anyone actually tested to see if the same cams of each brand make more power on a car???
Less friction on pistons going up and down usually makes a significant difference but i dont think its going to make a noticeable difference of how easy the camshaft spins (IN THIS DEGREE) if the hks cam lobes were jagged maybe, but they are pretty damn smooth.
PLus GSC doesnt make 280's or at least not yet so If you want max power HKS 280's seem to be the way to go. Other then a horrible idle those 280's are making the numbers.
Old Jul 29, 2005 | 12:06 PM
TalonRcR's Avatar
280's are only usefull if your going to build your motor and balance it. Not very streetable. Starts pulling good about 5500-10k, thats a rough powerband on the street. You can make 600hp with gsc 272/272 don't see any reason to put a 280 in.
Chris
Old Jul 29, 2005 | 12:10 PM
264/264 is good for someone who is on the stock turbo and needs a good idle
264/272 is good for stock turbo but someone wanting alot of power but while still attempting to retain a decent idle.
272/264 just seems weird and a waste of time in my opinion, but some like this
272/272 is for alot of power on stock turbo and someone who doesnt care about idle
272/280 hasnt been tested yet but probably would be a good idea to retain somewhat of an idle
280/272 again hasnt been tested and prob is just a waste of time, but i'm sure someone will do it one day and swear its the best combo
280/280 looking for maximum power, ideal for a larger turbo such as gt35R, but not necessary. buschur made around 15 more whp with these over the 272's. Most people with 280's dont complain of loss of low end power, seems only people complaining of it are people who dont have them. I havent seen one person with 280's say "I HATE THEM, NO LOW END POWER"
Old Jul 29, 2005 | 12:12 PM
jjm4life's Avatar
i dont mean to highjack the thread but im finding everyones input interesting and i had a quesiton of my own. what would the difference between a 272/264 vs a 264/272 be like? does anyone do it that way
Chris
dude, the stock turbo is still gonna hit full boost way under that, and it will still pull hard. i've been in a car with 280's on stock turbo and have seen plenty of videos online of idling, pulls, etc... they arent that bad. the idle sucks but for maximum power 280's is where its at
Old Jul 29, 2005 | 12:29 PM
johnny's Avatar
Registered User
thanks nolimitmotors well put
Old Jul 29, 2005 | 12:38 PM
xiaoni420's Avatar
the GSC 272's are awesome cams. no difference between the hks 272's other than the name. speaking for the 272's in general, these cams are badass and will make you tons of upper rpm power. i just got my cams installed and my car tuned the other week and made a baseline pull of 290whp after the install. after mark at turbotrix tuned my car i made 340whp. here are some numbers for you. the car idles lopey at times yeah, but thats only really when the car hasnt warmed up yet. when the car warms up, it idles just fine. regardless of the idle, the ride and the power of the cams while driving is ridiculous, its as smooth as it ever was, just with a sh*tload more pull.
Old Jul 29, 2005 | 12:40 PM
Rez90's Avatar
I have HKS 280's on my car with the stock turbo. With AEM...the idle issues are minimal. i mean VERY MINIMAL. you would have to really listen to the car for a few minutes to actually figure out it has cams. I'm not saying it idle's like stock but i am saying...the idle does not suck..if anything it just sounds a little meaner.
anyone who knocks 280's is only doing it cause they don't have them.......
and i'm not knocking other cams or cam combo's...i'm only speaking for what i have and my experience.
-joel
Old Jul 29, 2005 | 12:44 PM
UT_Evo's Avatar
I've been in a car with a dynoflash and 280s, idles the same as a car with 272s... never been in one with 264s but someday I plan on getting 264/272 buddyclubs as soon as I have the money to get them and have them installed.
Old Jul 29, 2005 | 12:47 PM
TalonRcR's Avatar
Most of that is correct but the best combo for street driving is the 272/264 combo since the stock setup runs a higher intake and exhaust duration it would make sense, stock duration are 238/234. The 272/264 makes alot more low end torque than the 264/272 both pull about the same #'s up top with mods. And I dont recommend 280's on a stock turbo either.
Chris
Old Jul 29, 2005 | 12:49 PM
TalonRcR's Avatar
-joel
How were your 280's before you got your aem? I'm not knocking 280's I'm just saying its not worth it on a daily driver unless you have a big turbo and ems.
Chris
