Amsoil or Mobil?
Old Jul 30, 2005 | 09:50 AM
RazoEvo's Avatar
Amsoil or Mobil?
Its time to change the oil, ive been using Mobil 1 10w-30, but a friend suggested Amsoil, anyone have any comments who have used it before?Thanks!
Old Jul 30, 2005 | 11:27 AM
Rastmp's Avatar
That oil is like water...(thickness)
I use it in my Toyota Highlander....I suggest you wait till your EVO has some miles on it..
Old Jul 30, 2005 | 11:34 AM
jwtodd60's Avatar
I tried Amsoil in my Evo. I never dynoed it to see if one or the other gave more power, but I did send samples out for analysis and they came back showing comparable levels of wear. See https://www.evolutionm.net/forums/sh...d.php?t=102173
JW
Old Jul 18, 2007 | 12:59 AM
bus's Avatar
bus
I'm actually curious about this Thread right here. I was hoping someone else could shed some light on AMSOIL motor oil. I heard this stuff works wonders, but not from anyone I know. I was curious to know about it though. ANYONE GOT ANY ANSWERS!?
Old Jul 18, 2007 | 03:18 AM
Ev0cRaZy's Avatar
It would be better than running Mobil 1. Mobil 1 went down a grade in oil, not really a true full syn. like AMS Oil is. AMS oil is great oil. There was a big thread a while back on all the oil, search and youll find everthing there.
Old Jul 18, 2007 | 04:40 AM
stryfetew's Avatar
I've nothing but good experience with AMSOIL products. Good IMO.
Old Jul 18, 2007 | 07:30 AM
El.BlueEvo9's Avatar
My friend swears by the Amsoil and he says it makes an improvement on his car . I use the Mobil1 10-30. It's cheaper at Walmart, atleast here anyways.
Old Jul 18, 2007 | 07:41 AM
Kordwood's Avatar
Subaru's burn Mobil 1. I put Amsoil in my Subaru and have never had to top it off. Amsoil has better viscosity retention. I'd use it before Royal Purple, Mobil One and Redline. Lab tests appear to suggest that it's better than any of these.
Old Jul 18, 2007 | 07:53 AM
TouringBubble's Avatar
I've heard that AMSOIL isn't great for turbo cars because silicon bits can form and that's not a good thing. I only heard this from one person though. He also recommended to not use synthetic in a turbo car at all.
My next oil change will be with AMSOIL. They were the first 100% synthetic manufacturer and are still one of the few. I've seen nothing but positive results from tests against other oils. I also plan to use AMSOIL in my drivetrain when I upgrade fluids.
BTW, if you are interested in AMSOIL, they have a preferred customer program that offers discounts. http://www.amsoil.com/opportunity.aspx. The buy in is $20/yr and offers 15%-20% discounts on retail prices. You come out better using this program if you purchase around $100 in products in a year. That's probably 3 oil changes or one full drivetrain fluid replacement.
No, I don't work for them ... I've just done a bit of research.
Old Jul 18, 2007 | 07:56 AM
Turbo Meg's Avatar
I run Amsoil in all my cars! http://www.amsoil.com/ You can find info on there site.
Old Jul 18, 2007 | 08:08 AM
Skim003's Avatar
I keep hearing about Mobile 1 is no longer fully synthetic. I tried searching for information and everything I found states that Mobile1 is fully synthetic. Are people confusing Mobile1 motor oil with other Mobile motor oil?
Old Jul 18, 2007 | 08:31 AM
Planet Evo's Avatar
It (mobil1) has never been fully synthetic.
AMSoil is a great product. Just a little more costly to run.
Old Jul 18, 2007 | 08:33 AM
JordanS4's Avatar
AMSoil is great. I think to be truly fully synthetic you would have to create the oil molecule by molecule but since no one does that I guess the actual meaning gets skewed a bit. AMSoil or Redline are both extremely good oils.
Old Jul 18, 2007 | 08:37 AM
Planet Evo's Avatar
AMSOIL is a true synthetic oil. NO crude base whatsoever.
Old Jul 18, 2007 | 09:15 AM
mplspilot's Avatar
What's Mobil?
Amsoil.
