defi d boost gauge instal question
Old Jul 30, 2005 | 07:34 PM
ddubb's Avatar
I just installed my defi d boost gauge following some instructions found here and on lancershop.com. The gauge works but I can get the gauge to light up. I've tried tapping it twice, once at the dimmer switch (green/white) wire and the other time at the cigarete lighter (brown) wire. Both aren't working, I would like to tap the wire in the center console somewhere. Any one have any ideas what I am going wrong or where you tapped your wires. I only had two wires with the gauge, black for ground and white for power source. Thanks for the help
Old Jul 30, 2005 | 07:37 PM
o2's Avatar
o2
check your ground. i used a spade connecter to ground mine to a bolt and i had the same problem.. all i had to do was tighten the bolt that the black wire was grounded to. if that doesnt work maybe youre tapping is wrong?
Thegame's Avatar
https://www.evolutionm.net/forums/sh...+guage+install
Old Jul 30, 2005 | 07:42 PM
ddubb's Avatar
^^^^thanks guys, that's one of the forums that I was following for the first try and counldn't get it to work, the last try was at the cig lighter spot. I'll try the ground b/c I didn't try to re do that. Thanks
Old Jul 30, 2005 | 07:49 PM
evo racing's Avatar
ur best bet is the guage dimmer wire..and yeah...check ur ground
Old Jul 30, 2005 | 07:51 PM
ddubb's Avatar
cool I'll try that again in a minute, just sucks that I have to take my whole center console apart again and reroute the wires.
Old Jul 30, 2005 | 09:28 PM
evo racing's Avatar
yeah sucks...just clean it up after...
Old Jul 31, 2005 | 04:58 PM
ddubb's Avatar
thanks guys, I did both sugestions and everything works fine now.
