Whats a good price?
Old Jul 31, 2005 | 11:54 AM
RazoEvo's Avatar
Whats a good price?
I have 3 autometer gauges i need installed, they are A/F, Boost, and EGT on the apillar. A shop nearby wants to charge $300 to install them, is that reasonable or to much?Thanks for any input, i dont think i even paid 300 to buy all of them.
Old Jul 31, 2005 | 11:58 AM
MyEvo8's Avatar
well the things is, that installing the egt, requires to drill at hole into ur exhaust manifold. and to do a clean job the shop has to remove your manifold out. $300 is a quote i got too, but i shopped around and got mine done by a "professional" for under 300. keep looking and good luck.
SIC SIK SIX's Avatar
that is way overpriced man. i got my gauges installed for 150 total. it was boost, egt, and oil pressure.
Old Jul 31, 2005 | 11:59 AM
Turbo Meg's Avatar
Seems high, I just had my HKS gauges installed last week Boost and oil pressure with control unit and pillar pod. The total cost 2 hous labor $130.
Old Jul 31, 2005 | 12:03 PM
SlowCar's Avatar
your dont have to remove the manifold. just seperate the manifold and the turbo assembly, stick a aluminum plate in between. Do your drilling/tapping, install the fitting/probe, open a gap with a screwdriver between the manifold/ aluminum plate-turbo assembly and start your car. The exhaust gases will blast all the metal bits out. let it cool down and reassemble.
Old Jul 31, 2005 | 12:04 PM
Thegame's Avatar
Do them yourself. I have all the how to's if you want them for those exact gauges. Hardly any tapping wires, used all add-a-fuses. I seriously am impressed with how well my gauge project turned out. 300 is a lot for a gauge install. You can get cams installed for that.
Old Jul 31, 2005 | 12:06 PM
RazoEvo's Avatar
I would but i just moved and have absolutely no tools but a jack with me, i can do the boost and af, the egt is the main one i was looking to get done.
Old Jul 31, 2005 | 12:07 PM
Thegame's Avatar
I did my egt with the manifold still on the car. I really think it's not that big of a deal as long as you are careful. Just keep letting the engine run until the hole is tapped.
Old Jul 31, 2005 | 12:08 PM
RazoEvo's Avatar
ill take the how-tos, id much rather do it myself, i just though it would be like 150 to get them done, not 300.
Old Jul 31, 2005 | 12:13 PM
MyEvo8's Avatar
what he said, i say "remove" as in the terms blasting the metal bits out.
Old Jul 31, 2005 | 12:14 PM
PoorBoys's Avatar
Install your own boost guage. It is very easy. The rest I would have done tho...
