Best For The Evo
Old Aug 4, 2005 | 08:55 PM
Eveolicious's Avatar
Best For The Evo
Hey, I will probably be getting an Evo within the next few weeks, and with it being a mod hungry car I will most likely mod it.
Before I do anything tho, I was just wondering from experience (people on here who have the part, or have used it before) what is the best for the Evo:
Exhaust
Downpipe
Intake
Blow Off Valve
Suspension (if not stock)
Boost Controller
Obviously some people don't have all of this, but I just wanna get some options of things I should look at. If you have any other suggestions as to what to do first, and whats more beneficial.. etc. Post em up, anything can help at this point.
btw.. I know there are probably threads about this kinda stuff throughout the forums.. but I wanted to have it all in one thread/post if possible.. which is why I posted it up.
Thanks.
Old Aug 4, 2005 | 08:58 PM
SlowCar's Avatar
on stock turbo:
intake = stock
boost controller = hallman mbc
Old Aug 4, 2005 | 08:59 PM
Warrtalon's Avatar
Not good enough, go search.
Old Aug 4, 2005 | 09:01 PM
Thanks for your help...
Old Aug 4, 2005 | 09:03 PM
IDRINKV8's Avatar
I have a Hallman Pro boost controller at 21 psi a buschur intake (short ram) Dynoflash reflashed ecu and i have a greddy sp2 catback in the mail as we type. Right now the car is a beast with the intake it runs rich but the dynoflash fixes that. So make sure you get all of your mods or the ones you have listed and then get a reflash from al at dynoflash. Also dont touch your boost let al do it.
Old Aug 4, 2005 | 09:08 PM
4-BNGR's Avatar
Old Aug 4, 2005 | 09:11 PM
bigjhoney's Avatar
Get some grounding wires, washer lights, some dubs, and a shift knob...and search while your at it.
Old Aug 4, 2005 | 09:17 PM
plokivos's Avatar
another worthless post by warrtalon.
buschurracing.com
you should check them out. great exhaust there.
Old Aug 4, 2005 | 09:33 PM
IDRINKV8's Avatar
Yes buschur is awsome
Old Aug 4, 2005 | 09:35 PM
aboh6leenz's Avatar
from what i have read so far:
exhaust: doesnt matter as long as it is good flowing any exhuast will work. (im getting a megan tbe because its cheap and has been proven to work and good quality- same might not say so only because its cheap and have no real proof)
downpipe: same as exhuast
intake: not sure i think just a drop in filter will do
bov/dv: jdm mr dv, aps dual vent bov.
suspension: coilovers, best springs are the hotchins
boost controller: halman cockpit boost controller
all the information i have searched/read from this board and have no experience with any.
Old Aug 4, 2005 | 09:37 PM
Gonzo0991's Avatar
Helix TBE
Old Aug 4, 2005 | 09:41 PM
plokivos's Avatar
no the exhaust, you want to avoid tapering exhaust.
buschur tbe is one of the exhaust that goes 3" all the way.
stock box is very stable on maf reading compare to cone filters.
duel vent's ok, mr dv is suppose to be good.
coilovers: stiffer then better, with weightbalance on each corner.
sway bars, rear tie bar, strut bar... they all help.
springs : espelir gt/asd, hotchkis
the cockpit controller is called hallman pro rx evo. in the how to section, i have my how to on install as well as pros and cons with 2 diagram on how to install.
Old Aug 4, 2005 | 09:42 PM
TRDHarrier's Avatar
dynoflash would be very good for the evo
Old Aug 4, 2005 | 09:46 PM
eling99's Avatar
first is the boost gauge.....my opinion...i would get the xede..i wish i went that route
Old Aug 4, 2005 | 09:49 PM
inariv5573's Avatar
True, but if you are keeping the stock cat like I plan to do, then there really is no need to go 3" all the way. Not to mention it expands your choices. Since many of them taper...I wonder why? Especially since top tuners such as HKS don't have full 3", they taper.
