Is It Posible????
Old Aug 15, 2005 | 01:41 PM
WHIPLASH VIII's Avatar
Is It Posible????
Hey guys someone was telling me that its posible for the evo to run low 12s and high 11s without cams or nitrous. i find it hard to belive. is this true? and if so what mods are needed? thanks
Old Aug 15, 2005 | 01:42 PM
lookEVO's Avatar
try alky!! and a few other things.
Old Aug 15, 2005 | 01:50 PM
any more?
Old Aug 15, 2005 | 01:55 PM
evo_il8's Avatar
you can do but i think cams r the most cost effective besides, nitrous
Old Aug 15, 2005 | 01:58 PM
lookEVO's Avatar
MBC (boost gauge) TBE, Intake, custom flash. i think thatll do. maybe i missed something.
Old Aug 15, 2005 | 02:12 PM
Ludikraut's Avatar
Agreed. W/out cams, I would think that a Vishnu stage 1, XEDE with NLS (no lift shifting), and racegas will do the trick (or any other vendors' equivalent mods).
l8r)
Old Aug 15, 2005 | 02:22 PM
Jakeg97's Avatar
gt35r
Old Aug 15, 2005 | 02:31 PM
Warrtalon's Avatar
Yes, it's true. I already ran low 12s without even a full exhaust, and I will try for high 11s this weekend with full, catless exhaust.
Mods:
- S-AFC
- MBC
- MR BOV
- Catless TBE
- ACT HDSS clutch
Stock everything else...
Old Aug 15, 2005 | 07:49 PM
lncrevoviii's Avatar
Cams (HKS Cams) are good help delivering power all the way to 7400, when stock most power is around 5500 and lift takes us to 7K, exhaust (Greddy/HKS) is good since stock is so restrictive, stock intake is the best becuase it blocks away all the heat and since the car is forced induction its allready getting 100% air flow, just get in a drop in filter (HKS, K&N) whateva there are so many. Get some headers and turbo dump. Some IC piping (injen) for smoother flow. A ecu flash is a must (vishnu, Xede).
I wouldn't put money on nitrous, our cars are allready making a lot of heat. save some money go for a bigger turbo (garret gt30 or gt35 kits) and FMIC, and if you are a good driver you are looking at low 11s to high 10s
Old Aug 15, 2005 | 08:21 PM
Warrtalon's Avatar
Don't agree here.
1) We don't have headers. The close equivalent would be a tubular manifold, which is nice, but not necessary.
2) What's a turbo dump? Pardon my ignorance here...
3) IC piping? Hell no, please don't, unless it's the LICP. Especially not the Injen...
4) A flash is CERTAINLY not a must - S-AFC or other piggybacks are fine.
Old Aug 15, 2005 | 08:34 PM
Don't agree here.
well for the injen thing i was just recommending companies that make IC piping, there a lot more but at the time that was running in mind and since it is carb approved now, I believe. Turbo dump is the part that is right under the turbo, one exit port to exhaust and other to IC. and flash i think might need for a smoother power band and for all the goodies to work properly. SAFC is also good, piggybacks all are good, but then again i rather have the flash done from a professional and just use SAFC for later purposes (track to street).
Ohh also i am still running stock (new owner) hehe . Just go with some of WARRTALON's suggestions since he has some of them EDIT: Most of them.
Hope this helps WHIPLASH EVOVIII.
Old Aug 15, 2005 | 09:17 PM
3000ways's Avatar
You need a 2005 model
Old Aug 15, 2005 | 10:25 PM
thanks alot guys if anyone els knows anymore please fill me in
Old Aug 16, 2005 | 03:18 PM
NIevo's Avatar
I ran a 12.3 with the mods listed below at 2300ft elev. and 92 oct. gas. If I were to go to Seattle and put in some 110+oct. and turn the boost up to 23-24lbs I bet I would be close to 11's. Most people from here that go to Seattle to race pick up .3-.5 sec. in the 1/4. So it is very possible depending on driver and weather/track conditions.
