Loud screeching noise from wheels?
Old Aug 17, 2005 | 08:53 PM
gl4662's Avatar
I've never had this problem before, but today I was driving and I had my music on and I noticed that there was a loud screeching sound. I rewound the cd to see if it was in the song, but it wasn't. Has anyone had this before?
Old Aug 17, 2005 | 10:22 PM
sud0u's Avatar
You are down to the wear indicators on the brake pads. Time to change it.
Old Aug 17, 2005 | 10:26 PM
mrbkkt1's Avatar
highly doubtful on an 05. mine squeals loud in reverse. also one time the other day it sounded like my bov was stuck for a couple of secs, made a loud squeal from the front like something was against the rotor. but i could not find the source and it never happened again.
Old Aug 17, 2005 | 10:31 PM
RC51EVO's Avatar
don't take the corner so hard
J/K
Old Aug 17, 2005 | 10:32 PM
jay_are's Avatar
i have had a loud squeal when i am slowing down at a stop light. i had read before on here somewhere that the brembos will do that from time to time. i have around 3800 miles on my 05, so i hope that it isnt time to changes brakes already (i do drive it hard on occasion, but very few hard stops) it does it about once every two weeks or so, and seems to be after a rain. maybe this is what you heard, maybe not. either way i hope this helps, and that you find out what it was.
Old Aug 17, 2005 | 10:34 PM
hanahawaiian's Avatar
your Brake Pads is pads out or Pads is Too dry.. if u have left over 3mm pads put Anti Squeak brake and grease on back of pads.. I think ur brake pads is out
Old Aug 17, 2005 | 10:40 PM
plokivos's Avatar
just look at the pads.
take the rim and tire out, turn the wheel, make sure you check both the inside and outside pads.
usually the inside ones are first to go.
Old Aug 17, 2005 | 11:08 PM
Thoe99's Avatar
How long do the stock brake pads usually last anyways? I have 27k miles on mine, and still going (that's with numerous autox's).
Old Aug 17, 2005 | 11:11 PM
Depend how u Drive.. i know it last long over 50 thousands mile if u good drive.. but Evo.. mostly we drive fast and slam brake.. prob less than 30 thosuands miles.. so u need check out if brake 2-1MM Replacement it!
Old Aug 17, 2005 | 11:26 PM
gl4662's Avatar
Well, the sound didn't come from braking, because when it happened I was just driving. The sound is really strong like a screeching/ scrapping type. Ah, anyways thanks guys for the input. I'll have my brakes checked anyways.
Old Aug 18, 2005 | 01:19 AM
lockjaw's Avatar
yeah i only had about 1200 miles and mine do it. now at 4000 miles they still do it from time to time but mostly after they heat up
Old Aug 18, 2005 | 07:08 AM
nnorris7413's Avatar
I have that exact same thing! I think it is the brakes, because the sound will appear while im cruising, but then when i lightly apply the brakes, it will go away. I think my rotors are warped so part of them are scraping against the pads. Next time you hear the sound, lightly apply the brakes and see if it goes away.
Old Aug 18, 2005 | 10:16 PM
lockjaw's Avatar
i was at the dealership today for an oil change and the service advisor told me this is normal.
Old Aug 19, 2005 | 08:16 AM
lol bs. Mine didnt start doing it until i had about 12k miles on it
Olms2468
Oct 7, 2013 10:34 AM
mrskoodle
Aug 14, 2013 10:18 AM
jrank3792
Feb 4, 2012 11:55 AM
Xcogg
Aug 29, 2010 12:31 AM
Drew1020
14
Nov 1, 2007 07:46 AM
