Estimate Quater Mile time?
Old Aug 22, 2005 | 02:44 PM
  #61
Thegame's Avatar
Who races and doesn't want to see their time slips? Even so, you should at least know what the other driver ran and base a time whether you won or lost, plus or minus your opponents time.
Old Aug 22, 2005 | 03:36 PM
  #62
4TUN8's Avatar
This chick is annoying.
Old Aug 22, 2005 | 04:15 PM
  #63
madweazl's Avatar
I'll have to investigate the connector you've mentioned then, it definitly isnt hitting a limiter with the clutch engaged. The previous owner said he didnt do a thing to it (53 year old man) and I believe him. Is it possible early build date cars didnt have the feature? Its an '05 MR in graphite gray with an early build time (car was originally purchased end of October). I'll try to track down the actual build date as I have every piece of paper work on the car.
Old Aug 22, 2005 | 05:26 PM
  #64
madweazl's Avatar
... iragent...
Calm down stud, we just wanted to see the time slip. Leave the name calling to PMs so the peeps trying to find usefull information can continue to do so. Dont want to end up with a locked topic.
Old Aug 22, 2005 | 05:48 PM
  #65
4TUN8's Avatar
you guys are all dumb mother****ers! She really did get those 60ft times her first time at the track... Why is it so hard to beleve that a girl can drive... Just because she can pull better 60ft times than you can now doesn't mean it's not possible or even true....
I never called BS on the 60 foot times. However, I'm annoyed that she comes here claiming nice numbers and then won't tell the E.T. like she's some sort of ultra secret 2 fast 2 furious "I live my life one quarter mile at a time" BS.
Old Aug 22, 2005 | 06:49 PM
  #66
Warrtalon's Avatar
No, that's not an early build date. I bought the first one to show up in the area in the end of October, and I haven't heard of any other 05 not having it. It's unlikely that he disconnected it, but something is wrong. I really think it's just a miscommunication between us, but you can go look underneath the dash behind the fuse box for any disconnected plugs...
Old Aug 22, 2005 | 06:53 PM
  #67
Warrtalon's Avatar
Anyway, girl or not doesn't matter. There's no reason not to share the timeslip or ET, and it's dumb to withhold the info after claiming an ET and MPH. It's all especially dumb to do that AFTER making a thread asking us to estimate her 1/4-mile time. Notice, she did not ask "what is the best 1/4-mile time a good driver can get with these mods." No, she was asking us to estimate what SHE will get with those mods as if it were to happen in the future...that's a different question altogether.
Anyway, we just want to see the timeslip. Nothing more; nothing less. You have to admit that someone who thinks she can hit a 1.5 60' due to cooler weather is not someone you'd expect to hit a 1.7 60' on the first try...
Old Aug 22, 2005 | 07:16 PM
  #68
o4whtevors's Avatar
man i hit a 0.8 60ft in -14 deg weather in my stock evo :?. here is the way to do it, first cold start the car (make shure its first thing in the morning). after you start it rev it to 7.8k, make shure you hold it to the floor this is realy important. then you will need to put a brick on the gas pedal so you can let it sit like that for about 20 mins at least. ok now that the first stage is over (that was to remove the stock rev limiter by bouncing through it) you will need to put some nitro in the tank and WD40 on the brakes ( the nitro is to help the bottom end grunt off the line and the WD40 is to get rid of any unwanted friction the brakes might have). now we are ready. ok get the car out to the track, line up, make sure to have atleast 2 friends with you (hopefully as dumb or dumber than your self). get one friend to sit on the hood and one on the trunk. now rev the car to your new rev limit of 10.5k and side step the clutch. make sure your friends do a barrel roll of the side of the car just as it starts to realy get moving to shead unneaded wieght and bam!!!!!!!!!!!!!!! the best time ever.
Old Aug 22, 2005 | 07:19 PM
  #69
DragNRacing's Avatar
I prefer the JATO rocket method myself. I've managed to cut some 1.6's or was that .6's. I dunno cuz I don't have my time slip
Old Aug 22, 2005 | 07:22 PM
  #70
o4whtevors's Avatar
btw please dont talk about my awsome way to get it done. i street race alot and like to get the drop on people .
Old Aug 22, 2005 | 07:34 PM
  #71
theo epstein's Avatar
I'll try her some cheap, 2,3 thousand a rattle
Old Aug 22, 2005 | 07:49 PM
  #72
madweazl's Avatar
Ok, I can go out to my car, start it up, put it in gear, push in the clutch, hit the gas, and it will rev to 7k (highest I've had it was about 7200) with out hitting any limiter what so ever.
Now, I havent tried to launch above 5200 or so but, at 5200 if I let out the clutch (letting it slip a bit to keep the revs up and keep the tires from spinning or bogging down if they hook) it will pull hard but it feels like a limiter engages at this point a couple times.
If somebody has a place where I can host a video I can shoot it tomorrow or the next day (pulling a 24 hour shift at work right now ) and try to demonstrate what its doing. I've described it best I can
Old Aug 22, 2005 | 08:26 PM
  #73
timzcat's Avatar
Closed.
Freddy302
Oct 11, 2016 05:55 PM
cesare77
May 24, 2011 11:11 AM
IXToes
Nov 21, 2006 10:36 AM
THANGEVO
Jan 23, 2005 09:02 PM
erikgj
Apr 22, 2002 08:35 PM
