Clunking noise when shifting hard??
Just got my 05' Evo VIII, and just got her over the 1000 mile break-in mark. Changed the oil and she's good to go.
When I'm accelerating quickly, there is a fairly loud clunking noise that comes from the rear of the car as the new gear kicks in. This usually happens when I lift the clutch pretty aggressively either from 2nd to 3rd, or 3rd to 4th. Is this just the Differential gears meshing and kicking in, and should I be at all worried about it. Or is this normal behaviour for this car??
Thanks,
Nick
Thanks,
Nick
i used to power shift with my hondas all the time. so the first time i power shift with the evo, i heard the clunk noise and i knew that means the evo doesn't like to be power shift, so i never did it again. it was only from 1st to 2nd gear.
OK ... so it sounds like maybe I was being a little too harsh on the tranny then huh?? I will try to let up on er a little more gently and see what happens. Just to clarify, it does happen the most from 1-2 and 2-3 ... not so much from 3-4 as my previous post stated.
botemarc
15
Aug 6, 2015 01:21 PM
