Carbon Fiber work?
Old Sep 11, 2005 | 12:54 PM
nnorris7413's Avatar
That isnt my kit, but its almost exactly like it. Mine just sold a couple of hours ago.
Old Sep 11, 2005 | 01:39 PM
ProccoEVO's Avatar
Hi can you tell me where did you get that kit from
Old Sep 11, 2005 | 01:43 PM
AznX TL's Avatar
probably www.dashkitstore.com
http://www.wooddashexperts.com/custo...at=2149&page=1
Old Sep 11, 2005 | 09:02 PM
WHTEVO's Avatar
not sure how much trouble you want to go through on the whole cf headliner but i remember reading a while back about a guy who did this along with the interior pillars in cf in his lancer and he had to take out the windshield just to get the headliner out and so on. it looked damn good when it was done but i dont think it would be something i would want to bother with, at least not right now. good luck though.
Old Sep 11, 2005 | 09:03 PM
WHTEVO's Avatar
not sure how much trouble you want to go through on doing the whole cf headliner part but i remember reading a while back about a guy who did this along with the interior pillars in cf in his lancer and he had to take out the windshield just to get the headliner out and so on. it looked damn good when it was done but i dont think it would be something i would want to bother with, at least not right now. good luck though.
Old Sep 12, 2005 | 12:12 AM
Wave's Avatar
Originally Posted by akunochi
do you know which epoxy? I have built fiberglass sub boxes. how would you recommend going about this? Would I remove the stock liner strip off all the clot and use the base piece to fiberglass over then finish with a layer of CF?
Basically yeah. I'm no CF/Fiberglass expert though. That's why I found a good installer It was a bit of an experiment when I did it (he'd never worked with CF specifically). Since then, he's done a LOT of CF work though.
As far as what to use, I got my supplies from http://www.uscomposites.com . Check there epoxy section for a good clear coat. I'm sorry I can't be more specific, but 1) I did this 3 years ago and 2) my installer basically said order this that and this, so I did.
Check the epoxy section for what you need for a clear coat resin and the fiber section for your actual carbon fiber cloth. Good luck
edit: one tip, be careful mixing the epoxy based resins w/ the polyester resins. They can react with each other and kill the finish...
Old Sep 12, 2005 | 04:02 AM
WarmPepsi's Avatar
yeah, basically, if you want it looking mint, you're gonna have to pull it down/out.
Smooth and contour it to your perfect liking, then layup over it.
Use epoxy stuff, if you mix it with polyester, they will not adhere (to any strength, if at all)
When you mix resin, mix small batches, so it doesn't get warm and go off in your cup/bucket/etc. Also, you probably want to ply over the outside when you're done (not sure what the composite place would call it, i know it as "peel ply"), to give it that finish thats smooth. Then bury it in clear.
Rather involved process to get it out, it sounds, but best of luck, and be sure to post some pics if/when it's done.
Old Sep 12, 2005 | 04:51 AM
akunochi's Avatar
what is this peel ply? Is it a process specific to CF?
Old Sep 12, 2005 | 06:50 AM
akunochi's Avatar
oh yeah and anyone have the directions to removing the headliner???
Old Sep 12, 2005 | 08:08 AM
WarmPepsi's Avatar
nah, it creates a flat, bonding surface.
for lack of a better term, it's a clothlike rolled fabric, similar to wax paper i'd say. Enables you to bond right on the surface. I gotta take some pictures today, i'll try and take one to show you the difference.
Old Sep 12, 2005 | 09:15 AM
lookEVO's Avatar
you would have to make the headliner in the car right.
Old Sep 12, 2005 | 09:21 AM
BoostWhore's Avatar
ive seen a vw with a cf headliner in my oppinion it didnt look that great i think it would be hard to make it look really even. Also ur headliner will end up being heavier b/ it will have to be fiberglassed to make it stronger and give u a hard surface to bond the cf to. atleast thats what i think u would have to do
Old Sep 12, 2005 | 03:14 PM
WarmPepsi's Avatar
right, you're gonna end up making it heavier with the filler to get it just right to layup against.
it's purely a cosmetic use.
Old Sep 12, 2005 | 05:47 PM
akunochi's Avatar
yeah I like to have show as well as go. I'm sure my motor Ia m going to build will handle the weight...
Viciouz
Mar 10, 2009 03:18 PM
edtxag
Aug 9, 2006 09:49 AM
Sakamara
Jun 26, 2005 08:53 AM
Derek888
Sep 19, 2004 06:59 PM
sno_evo
Dec 12, 2003 12:50 PM
