Maf + filter cleaned
Old Sep 12, 2005 | 11:59 AM
k270kmh's Avatar
Talking Maf + filter cleaned
My car is much smoother now. Reving faster.
Thank you for those who informed me about the oil from the K&N on the Maf sensor.
I cleaned the MAF with a contact cleaner spray. Do not touch the sensor!
At the same time I tightened all the intercooler clamps.
Old Sep 12, 2005 | 12:02 PM
krafty's Avatar
May I ask how you safely cleaned the MAF sensor?
Old Sep 12, 2005 | 12:03 PM
krafty's Avatar
NM...I just read the rest of your post...oops
Old Sep 12, 2005 | 01:52 PM
yesevo's Avatar
U Can Clean Maf With Electronic Cleaner Or Some Minor SoapY WATER
Old Sep 12, 2005 | 01:58 PM
webguy330i's Avatar
I used carb cleaner (marked as safe for sensors) and all has been well in the last 5k miles...
Old Sep 12, 2005 | 02:03 PM
dridge11's Avatar
This information may come in handy. I've got a nice oily K&N to install in about 500 miles.
Does it just seem bogged down because the sensor is dirty and doesn't get an accurate reading?
Old Sep 12, 2005 | 02:20 PM
DaWorstPlaya's Avatar
Makes sense, as the readings from the sensor are steadier ... ECU compensates with correct fuel = smoother revs
Dridge11: Dry the crap out of your K&N before you install it, use a hair dryer, leave it in the Sun, even bake it in an oven if you're feeling brave ... Then use it and monitor it for the first few times you take your car on a spirited run. Make sure there are no oil spots on the base of your air-box. If there are, clean it up with a rag immediately ... repeat until you see no oil spots and then you can use it as a higher performing regular filter ...
Old Sep 12, 2005 | 02:29 PM
bigfishs's Avatar
Could we have the link to the original thread please?
Old Sep 12, 2005 | 02:35 PM
dridge11's Avatar
It'll be another couple weeks before I put it on. Should I just take it out of the box and set it in my hot garage for that time?
Old Sep 12, 2005 | 02:43 PM
yes ...
Old Sep 12, 2005 | 02:51 PM
ZK's Avatar
ZK
That's why I use a dry type filter...
Old Sep 12, 2005 | 03:41 PM
GOKOU's Avatar
I have the BR filter and was planning to clean it along with the MAF as well. No oil on the filter but I'll try to make sure there's little to no water before installing it back in. I don't think a little of water will hurt it.
Old Sep 12, 2005 | 03:42 PM
hueman's Avatar
i didn't even think that the maf needed regular cleaning
Old Sep 12, 2005 | 04:20 PM
ZK's Avatar
ZK
Here's an article on how to clean a MAF sensor. The sensor is very delicate. If you don't know what you are doing, I'd avoid it. You can damage the sensor and in turn your motor.
http://spydermagazine.com/2002/March.../maf_clean.htm
Old Sep 12, 2005 | 04:22 PM
evo_knight's Avatar
had no idea about the cleaning
