A failed experiment (sigh)
Old Sep 15, 2005 | 04:40 AM
  #31
jxn evo 8's Avatar
I actually went a full tank with shifting no higher than 3k. I got 22mpg.
Old Sep 15, 2005 | 05:22 AM
  #32
smackdaddy's Avatar
lol, I get 25 mpg just about every tank, with plenty of spirited driving
Old Sep 15, 2005 | 05:32 AM
  #33
jonathanVIII's Avatar
this is prolly a stupid question but is the first half of the tank larger than the last half? i get 200miles on the first half on the highway. but 400miles on a tank is tough to swallow
Old Sep 15, 2005 | 05:36 AM
  #34
lexat20's Avatar
Originally Posted by 4TUN8
Don't even bother trying, just buy a car that can't go fast and put the Evo in the garage if you want to get good gas milage. This car was meant to be driven the way Jenna Jameson was meant to get.....well you get the point.
It's a tool, use it the way it's supposed to be used =)
This is by far the best quote I have read on this forum yet!
Old Sep 15, 2005 | 05:57 AM
  #35
purecoda's Avatar
i've noticed this too. my guage red just barely above a half tank left, but it only took about 5 and 1/2 gallons to fill up. if our tank is 14.4 (i think) then it should have took something more like 7. i think you've got at least a gallon left when the light comes on, maybe 2.
Old Sep 15, 2005 | 07:01 AM
  #36
rsboy's Avatar
24mpg calculated after filling up again last week. Had to stay under 4K rpms when shifting and kept the boost under 0 whenever possible, except when passing slow idiots on the freeway, I'd hit 1.5bar. This is driving on stop-n-go and freeway. And my car might still be a bit rich since I don't have my lower IC pipe yet which it was tuned for.
It's kinda hard to not boost, but this car is still pretty fun driving "normally". But now that gas went down under $3/gallon here for 93... "air-drying" the car is fun again!
btw... I think the gas warning comes on at about 2 gallons left in the tank. I've done/noticed that a few times.
Old Sep 15, 2005 | 12:05 PM
  #37
AWDrift07's Avatar
it has to do with the gauging system. for the first couple of gallons or so, the float inside the tank is submerged because it cannot float any higher and is pushed against the top of the tank so you get a full reading for a long time. then the reading suddenly falls as the float actually floats in the tank. Gas gauges are inherently inaccurate because of this and the fact they use a electronic multi tap system. Simply put its not accurate.
