Dyno time! Anyone care to guess my #'s?
Old Sep 21, 2005 | 10:00 AM
  #46
cpdevo31's Avatar
the numbers aren't much to look at, but once u sit in the car, u dont care about the numbers. i put down just over 282whp with 264 torque. had a run with justchil on the interstate the other night. we are pretty much the same, minus the fact i have "generic" mods and he has cams. he pulled pretty good, but both of us took a blown GT. andy, once i get my cams we will try them again. wanna see how much they improve it.
Old Sep 21, 2005 | 10:58 AM
  #47
Airpoppoff's Avatar
I defintely think because you got the cockpit controller youll get at least an extra 10hp
Old Sep 21, 2005 | 01:54 PM
  #48
TeenEVOwner's Avatar
I would really like to see either of your guys evo's in person... I havent seen an evo in Parkersburg in 6 months... and that guy moved to Hunington...so now I am the only evo in the Parkersburg/vienna/williamstown/marietta, OH area....
Old Sep 21, 2005 | 02:01 PM
  #49
justchil's Avatar
I'll be down at Kanawha Valley Dragway on Saturday.. Mine is nothing special to look at. cpdevo's engine is nicer looking for sure. I had bought a BR heatshield which would make things look a little better but the studs were aluminum and broke off.. so I'm back to the stock shield.
Old Sep 21, 2005 | 02:15 PM
  #50
bdking57's Avatar
Its nice to see this dyno will take people back to reality.. all this talk of 300+whp on stock turbo on pump gas is (without alky) is way to high.
Old Sep 21, 2005 | 04:18 PM
  #51
cpdevo31's Avatar
300whp too high on stock turbo and pump gas? i am at 282hp with the engine still bone stock. all i need is to get cams and i will be over 300whp.
Old Sep 21, 2005 | 04:20 PM
  #52
cpdevo31's Avatar
come on down. i have some family members up there, if i am ever up that way i will let you know and you can check it out.
Old Sep 21, 2005 | 04:52 PM
  #53
scherejs's Avatar
Originally Posted by GOKOU
No problem and no harm no foul . It was good that you pointed the scenarios out.
Yes the reason for that was when the original owner bought the pipe from you he had it flange for a turbo xs rfl which was a VTA bov. Not sure what he did to the MAS pipe but it was screw up, the recirculating bung pointing downward. I wanted a recirculating bov so my brother had to cap off the original flange (vta bov) and made a 1g flange. He also had to cap off the bung on the MAS pipe and open a new one. The pipes were then powder coated to blue. It was all for free since he is a welder and the company he works for does powder coating.
I have the BR receipts
Like I said before I believe there's an exhaust or vaccum leak somewhere on the car that's preventing it to run maximum potential. During cold start the rpm and vaccum on the boost gauge will fluctuate like it's trying to find the correct A/F. I also can hear tapping\ticking noise from the DP\lower pipe area. When I first had it flash the car was running very strong. After the clutch installment it was never the same.
Are you sure it's not your downpipe leaking at the o2 housing? I had this problem after I installed my clutch. I had a little ticking sound and found out that it was a leak between my downpipe and o2 housing.
Old Sep 21, 2005 | 09:34 PM
  #54
GOKOU's Avatar
I'm not sure but that was my initial guess. Did you have to remove the entire DP and then put it back on or did you just loosen the DP bolts and refit it? How did you fix it?
Thanks.
Old Sep 21, 2005 | 10:05 PM
  #55
Warrtalon's Avatar
Not sure why people love to throw around the term "bone stock" so much. Almost all of us have "bone stock" engines, so that's not needed as a qualifier here. The hp this guy is talking about is on an unmolested Mustang Dyno. Did you hit 282whp on Buschur's dyno? I hit 295whp on a Dynojet without cams, so obviously I'd go well over 300 with cams, but that's not relevant to bdking's comment for obvious reasons.
Old Sep 22, 2005 | 11:46 AM
  #56
cpdevo31's Avatar
yea, 282whp on Buschur's mustang dyno.
Old Sep 22, 2005 | 03:04 PM
  #57
scherejs's Avatar
Thanks.
i removed the whole dp and noticed the leak because you could see on a portion of the dp there was soot where exhaust was escaping. I made a gasket myself out of super high temp gasket material that i special ordered through napa. now i don't have any problems.
Old Sep 22, 2005 | 07:57 PM
  #58
I would like to try and come down to KVD but I have to work ...I think some of my friends may go down... yeh my evo is nothing special (other than the fact that it is an evo)...just a little bit of mods here and there... I will be attending the last Nopi event of the year up @ Norwalk...if you guys are going to go up, u could stop by P-burg and cruise up!...
Old Sep 22, 2005 | 07:59 PM
  #59
It seems like my only reasons for going down to charleston are autox, the mall...and thats bout it... if you guys are going to get into anything before winter kicks in, just shoot me a PM and let me know!
Old Sep 23, 2005 | 04:10 AM
  #60
cpdevo31's Avatar
will do, if u dont mind pm me some more info on the nopi event. if i am off, i may try to run up there also. andy you interested in making the drive?
