Looking to get around 50 crank hp...
Old Sep 18, 2005 | 10:36 PM
prospectevoER's Avatar
I just recently purchased an 05 evo. Im looking to get around 50 crank hp IN THE SAFEST WAY possible. What would you guys suggest? Also what would give better results between changing the downpipe and removing the cat or just changing the catback? When you change the downpipe does it remove the cat also or would you have to get additional piping as a cat delete?
Old Sep 18, 2005 | 10:38 PM
Compjoc's Avatar
Change the cat-back first if ur going to do exaust. But for 50 hp, do full turbo-back exhaust and a reflash.
Old Sep 18, 2005 | 10:45 PM
justchil's Avatar
If you can get a good custom dyno tune locally... I'd say get a mbc.. maybe a drop in filter. Exhaust would be great but you could gain 10-20whp just with a tune.
Old Sep 18, 2005 | 10:58 PM
Well i know with the mbc boosts holds much better and the turbo spools faster but is it safe for the boost to hold all the way to redline without tuning for it. Also is an mbc consisten without spiking or creeping?
Old Sep 18, 2005 | 11:09 PM
badhabit90's Avatar
Cool
3" down pipe, 3" exhaust cat back, and a mbc set at 20psi will get you there. it is safe even without a tune. once you tune, you will notice a smoother power band.
Old Sep 18, 2005 | 11:12 PM
thanks guys. Im really looking for 50 crank horspower nothing more so the least i can do the better. You think by getting a catback only and a custom flash i can achieve this without getting the mbc??
Old Sep 19, 2005 | 01:15 AM
TwoMix9900's Avatar
I wouldn't recommend MBCs...more boost = more strain on the engine/turbo = shorter lifespan
Rule of thumb: more power = shorter lifespan
Old Sep 19, 2005 | 06:00 AM
Jeff_Jeske's Avatar
On my 03....I picked up 57WHP with 3" CATLESS turbo back exhaust, JDM BOV, and an XEDE piggyback tune with boost at 22PSI via XEDE.
But my car was SUPER rich with just the factory ECU.
Old Sep 19, 2005 | 07:24 AM
badhabit90's Avatar
Cool
Old Sep 19, 2005 | 08:24 AM
so you guys think a catback and a custom tune flash will get me 50 crank hp?
Old Sep 19, 2005 | 08:40 AM
Kee1pride's Avatar
why would you care about crank anyhow?
wheel horse power is the only number that maters.
who cares how much horsepower you have that you can't effectively use?
lol
Old Sep 19, 2005 | 09:11 AM
Warrtalon's Avatar
Hey, if you're in NOVA, you should be on our local club asking this. We'll hook you up with some good info and point you to our vendor sponsors for great deals on parts and/or installation.
The suggestions in here are good, but you need to not worry about crank hp, since no one can measure that.
Old Sep 19, 2005 | 05:02 PM
thats very true. so i was think about 40 whp. ill definately check out the local club. thanks man.
Blacksheepdj
Dec 2, 2016 08:31 AM
blew_by_u
Lancer Troubleshooting
Jul 22, 2016 09:22 AM
Pal215
15
Nov 2, 2015 10:15 AM
dubbleugly01
Automotosports - Illinois
Nov 17, 2006 01:29 PM
MitsuJoe
216
Jul 19, 2005 04:54 PM
