HELP! - Shifter rotated after alignment
Old Sep 19, 2005 | 01:46 PM
anjapower's Avatar
better check your alternator fluid and blinker bearings as well...crooked shifters are a precursor to those going bad as well. Hopefully you'll get it covered under warranty.
Old Sep 19, 2005 | 02:00 PM
o2thag's Avatar
Originally Posted by TrEvoRS
Thank you all for all the responses and checking the shifter arm on yours. I am convinced that I am either going mad or hallucinating This is like leaving your bike resting to a pole and finding the pole going through the frame when you return...
I can imagine how this whole thing sounds but I have no explanation of what happened to rotate it and I certainly can't rotate it back to normal-solid position (and I tried). I will let you all know if I find anything else to watch for other than the above explanation
This is more like leaving your bike resting to a pole and then coming back to find out your seat is turned 90 degrees. It's just the shift knob. Don't know how else to put it.
Old Sep 19, 2005 | 02:08 PM
badbrain's Avatar
Put some muscle into it and just twist the knob back. If you take the car back to the alignment place, they will laugh at you.
Old Sep 19, 2005 | 02:24 PM
Dan_EVO's Avatar
Maybe the threads are messed up on the shift lever, remove the shift knob and see if all the threads look good.
Clipse3GT
12
Jul 25, 2009 01:26 AM
tmt502
Dec 27, 2007 06:07 PM
David Buschur
Oct 9, 2006 11:32 AM
Lgkaos
West Region
Aug 17, 2006 10:07 PM
LancerOZ
Nov 20, 2004 12:20 PM
