Recall C0504H
Old Sep 19, 2005 | 03:20 PM
EnJaNir's Avatar
Recall C0504H
Was at the dealer picking up some touchup paint today and found out that there is a recall out that was just released regarding the Turbo Coolant Hose. Just wanted to make sure that people knew about it if you didn't already.
Unlrelated I was amazed that the Rally Red touchup paint P23 comes in a pen labled Pheonix Red and appears to be much darker then the actual color. However upon testing it seemed to be ok.
Old Sep 19, 2005 | 03:22 PM
UT_Evo's Avatar
Yep, the Apex Silver pen was called something funny too, and then matched more perfectly than I could've imagined.
Old Sep 19, 2005 | 03:24 PM
virtex's Avatar
how much are the touchup pens?
And to stay on track what years does this fall under 03-05?
Old Sep 19, 2005 | 03:25 PM
2literv8eater's Avatar
There is a post regarding the recall, mine wasn't affected. There is 6 month period of affected cars.
Old Sep 19, 2005 | 03:26 PM
oak2207's Avatar
Link?
Old Sep 19, 2005 | 03:28 PM
EnJaNir's Avatar
I know the recall is at least for 05 models since mine is an 05 and the recall came up on their system for my vehicle. I am not sure if previous models are affected.
My touchup pen was 12.60
Old Sep 19, 2005 | 03:30 PM
Affected models are 05, manufatured between 12/10/04 -6/06/05
Old Sep 19, 2005 | 03:32 PM
EnJaNir's Avatar
Well I did a quick search and did find that this was posted.
https://www.evolutionm.net/forums/sh...hlight=recalls
Sorry for the repost, but for those who didn't know still good information because I have not recieved any notice in the mail.
Old Sep 19, 2005 | 03:34 PM
Beat me to the link, I called Mitsu and gave them the VIN # and had them check it, all good for me
Old Sep 24, 2005 | 12:46 PM
EnJaNir's Avatar
Ok so I got the recall taken care of and the car sounds different now.
When accelerating when I shift from 1->2->3 etc I hear more of a wooosh da da da. Im just curious as to why this sound is soo noticable now after the recall and prior to the fix I was not able to hear it. Any thoughts people?
Old Sep 24, 2005 | 02:24 PM
TeamAccolade's Avatar
thats b/c its the paint from the Lancer... it should match even with the different name, some color vary a bit... but the paints should be so similar it would be un-noticeable...
Old Sep 24, 2005 | 02:34 PM
dridge11's Avatar
I just picked up my 2005 a month ago...how do I find out if this recall involves my car? Just go to the dealership? Or is there somewhere I can find my build date?
jjm4life's Avatar
hows the touch-up paint look? my 05 already has a few chips that id like to clean up but i can just imagine a touch up pen looking worse than minor chips
Old Sep 24, 2005 | 03:39 PM
Look for a lose hose at the BOV maybe, or something with the intake. The service on the recall should not cause that sound. I never trust anyone else working on my car, they must have forgot to connect something.
Old Sep 24, 2005 | 05:16 PM
EnJaNir's Avatar
In regards to the touchup paint: havent tried yet
I am really leaning toward something is either loose, or the replacement part is causing this, but seeing how it is a coolant hose I doubt it.
Per the recall document that i downloaded the required operations are
-remove rad cap to release sys pressure then reinstall
-remove air intake duct and air cleaner assy
-remove air flow sensor connector and clamp
-remove intercooler hose
-remove air intake hose
-replace turbo water feed hose
-reinstall parts
-bleed air from system
-replenish coolant
-mark that it has been done
-confirm all bolts etc are secure
-confirm coolant level
-start car make sure you dont hear anything
Perhaps when they reinstalled the intake it isnt sealed correctly making the sound more audible...I am sure that something is goofy though.
