My intake question
Old Sep 23, 2005 | 08:17 AM
MitsuEvoIIX's Avatar
My intake question
so ive been wondering what intake to get for my evo...should i get a drop in filter? or something like an hks rs and then get a tune? which would be more benificial? and with a drop in filter can you her the turbo and the bov more?
Old Sep 23, 2005 | 08:19 AM
slow_evo's Avatar
Drop in is all you really need.
bluebanana23's Avatar
to hear it, you will need a cone filter. I suggest the Injen since it comes with a hardpipe as well.
Old Sep 23, 2005 | 08:24 AM
but i seen when you take the box out the maf sensor is right there so how would a cone filter fit? and adapter would be needed right?>
Old Sep 23, 2005 | 08:25 AM
F&I-EVO's Avatar
K&N drop in, thats all you need!
Old Sep 23, 2005 | 08:29 AM
do you see some improvements with the drop in?
Old Sep 23, 2005 | 08:33 AM
deadbeatrec's Avatar
ok for those who say drop in is all u need, what is your reasoning for this. if the stock intake was soooooo good do u think most evo owners would keep the stock plastic thing. go with an aftermarket intake. u will be glad u did, just stay away from the k and n typhoon for the evo because i have herd it is hard to tune. trust me u will love the open air intake a lot more than just the stock box. i ahve gone that drop in route b4 with other cars and its by far not worth it.
Old Sep 23, 2005 | 08:41 AM
so with the hks rs will i need a tune right away? and if not will my car run like s**t?
Old Sep 23, 2005 | 08:45 AM
not right away but do some mods together and then get it tuned. i ran my aem intake for like 4 months b4 i got a tune
Old Sep 23, 2005 | 08:51 AM
DaWorstPlaya's Avatar
Drop-in filter, because a lot of tuners have come you and said the stock air box is not restrictive .... plus an aftermarket intake has a greater chance of messing up your MAF readings and the minor gains over a drop-in aren't worth the effort in tuning ...
Old Sep 23, 2005 | 09:01 AM
Smike's Avatar
RMR or cone if you want to hear it or drop in if you want to look stock, as long as you dont change the piping you will be ok. The piping will require tuning and its not worth the cost or minimal gains.
Old Sep 23, 2005 | 09:15 AM
Smike's Avatar
Yes, the RMR has a plate adapter for the MAF. As for gains a few hp, but you can hear the turbo on DV much better.
Old Sep 23, 2005 | 09:47 AM
slow_evo's Avatar
Because they are used to hondas. "CAI makes it go HELLA fast....."
Old Sep 23, 2005 | 09:53 AM
navypaul's Avatar
ok usually i try to look at it this way what am i trying to accomplish with the filter mod i want to get colder air to the engine but putting an open filter just like that taking away the stock box just leaves it vunerable to alot of heat thats trapped under the hood so some kind of shielding is required u can use the open filter just make sure its receiving a good supply of cold air thats why alot of people dont like putting open filters and prefer swapping just the filter which is a good and safe idea but there are filters outhere that have good shielding and are well protected agains heat from the engine but the downfall is that they might b a bit expenssive personally im looking into buying the ARC box
Old Sep 23, 2005 | 10:01 AM
dbdude's Avatar
I have the HKS RS with no tune. It runs the same but now i can hear the stock BOV pretty loud making the WOOSH sound. Once you get the flash it will make the HP difference.
