Would "the mothership" like to respond to all these 180awhp threads??
Old Mar 12, 2003 | 04:05 PM
  #46
dazz's Avatar
Originally posted by rdrkt
Shiv: I have no idea why you are using that dyno. They do make AWD dynojets. If I was someone that sold tuning services and turbo packages I would want my numbers to be comparable to everyone else’s. This 17% difference seems bad for business to me.
One has to look beyond their own backyard first to find out why tuners in other country have laugh about our US dyno tuning methods for years.
As for Dynojet "AWD dyno," its actually just a 2WD dyno with a add-on attachment.
Like Shiv said, "It's a hard habit to break." Hopefully this will shed some light for some "DSM" fans.
Old Mar 12, 2003 | 04:09 PM
  #47
rdrkt's Avatar
They can laugh all they want but our cars are much faster than their cars. Until they can put a list together like this I will stick with our ego stroking dynos.
Old Mar 12, 2003 | 04:12 PM
  #48
luminari's Avatar
Maybe because Shiv is out for more accurate measurements to actually improve his products rather than sling more goods based on inflated HP numbers?
Anyways, 180 AWHP is low, but isn't it strange how the Evo VII in SCC's Evo vs. WRX article put down 247 HP to the wheels on a Dynapack 6000? We can argue about how Shiv's dyno makes our cars look weak, but if it's precise, at least we can compare cars like the Evo, WRX, S4, etc. which have been dynoed on it.
  #49
dazz's Avatar
Although this article was written by a WRX driver, but this may give a good insight on the differences between the two dyno debate.
Hi Everyone,
I'm a curious person (just like the most of you), but I found it increasingly difficult to understand who's products makes how much power. But from all the posts and dyno plots, it seems that everyone had slightly different scenarios (so no apples-to-apples comparison). So I'd figure I'd try and help out our community by ponying up the $$$ and getting some real-world answers.
So what was the plan for the today? Let's take the exact same car and go to two different dynos to see the differences (keeping as many variables the same).
Who are the gineau pigs? ATP (Fremont, CA) using their in-ground Dynojet and Vishnu Performance Systems (Pleasanton, CA) using their DynoDynamics. They are approximately 20 miles from each other (25 minutes). And finally my car ... 2002 WRX (silver - its the fastest color) with 25,910 miles on it ... the mods are a full Vishnu Stage 2.
What was the test setup? Of course with my luck, the fan ATP used to cool the TMIC broke. Oh well, to be consistent NO fan was used to cool the TMIC at Vishnu's either. I've also seen some posts about the fans used to cool the radiators ... let me tell you that the one at Vishnu's was massively stronger that the one at ATP (so we pulled it a lot farther away that the one used at ATP). I don't think this makes too much of a difference, since the engine coolant temps stayed the same. For those **** people ... ATP was 60deg.F and Vishnu was 61deg.F and I don't think there is more than a 100' of elevation change. I did forget to measure the temperature of the intercoolers (but oh well). The car were driven to their each location, sat around for 20 minutes, driven onto the dyno, sat around for another 10 minutes and then first two runs were pulled and printed. That's all folks ... we don't want to make this more complicated that it needs to be.
The Results:
ATP (Dynojet) - 275.8whp and 232.2 torque
Vishnu (DynoDynamics) - 224.7whp and 192.2 torque
So depending on how you look at it ... Dynojet runs 22.74% higher than a DynoDynamic or DynoDynamic runs 18.53% lower than a Dynojet (with regards to whp). Check out these graphs ... (oops ... I can't figure out how to get multiple attachments with a single post)
Interesting observations ...
Setup on the Dynojet vs. DynoDynamics ... all I got to say is that it was a lot harder getting my car on the Dynojet ... first thing was that we didn't get the tracks pulled apart far enough until we rolled the car on to it (so we had to back off the car, stretch the dyno and put the car back on). The second thing, was that it was tough getting the car balanced on top of both rollers ... so about 20 minutes elapsed from getting into the garage to the first pull. The DynoDynamics was really simple ... drive car onto ramp and fall into the first set of rollers (in case you didn't know they have 8 rollers - two for each wheel) and use a simple control to slide the rear rollers into place, strap it down and you're ready to go (5-6 minutes tops). The other thing I noticed was that you had to bring the car to a complete stop on the Dynojet ... the DynoDynamics could run back-to-back pulls really quickly - you don't have to bring the car back to 1st gear.
The important thing I've learned is that when you want to know the differences between modifications, you need to have testing tools that repeatable (ie. stick to the same dyno and record the environments - so you have the same correction factors in play).
Conclusion
So what have I accomplished with all this ... nothing, my car still make the same power it did going to both dynos. So, I wanted to help put some of those concern people at ease ... I'm sure you're making the power you made (since you have dyno plots), just know there is a significant difference between dynos. All I'd like to see are vendors advertising the % differences they have measured (and world peace).
HTH!
Old Mar 12, 2003 | 04:13 PM
  #50
Nzo's Avatar
Nzo
rdrkt you have obviously lived a very sheltered, and ignorant life.
  #51
Obsoleteasian's Avatar
off-topic.. but i wonder what people are thinking.. is it good to get the oil changed within the next few miles to get all themetal pieces out.. of the new engineand whatnot... has anyonen with an evo done it. yet.. vishnu.. yay or nay for early oil change?
Old Mar 12, 2003 | 04:15 PM
  #52
rdrkt's Avatar
Originally posted by KK
I wish someone around here had a Dyno Dynamics unit to use
You are in the AWD tuning Mecca. Altered uses an awd dynojet and TurboXS uses a Dynapack are either of those close enough?
Old Mar 12, 2003 | 04:42 PM
  #53
rdrkt's Avatar
Accurate how exactly? Yes the dyno will put more load on the car and it will make it a bit easier to tune specific spots on the powerband but I fail to see how this has a substantial benefit. If you really want to be that picky ANY dyno is going to do a poor job of measuring the exact power of a turbo car. No shop fan is going to be able to simulate the proper air flow over an IC and to my knowledge it doesnt correct for wind resistance at speed either. IMO for WOT tuning nothing is more accurate than the strip or dare a say an abandoned country road.
As for Shiv and his commitment to deliver outstanding products and tuning. I still haven’t see a car tuned by his shop that did anything special. For as much as SCC fawns over him and as smart as he says he is you think he would have had a few power house cars by now.
Old Mar 12, 2003 | 04:44 PM
  #54
rdrkt's Avatar
That is some pretty tough talk. Do you have an tech to substantiate that? Or are you just spouting off? I mean I am hitting 117 traps on pump gas with a factory internal motor with a SAFC for tuning I have to be doing something right.
Old Mar 12, 2003 | 04:46 PM
  #55
BADWRX's Avatar
What is this clown smoking? Think, and research, before you speak.
Ever heard of the Rigoli Bros? How about JUN Auto?
Old Mar 12, 2003 | 04:51 PM
  #56
BADWRX's Avatar
And most sophisticated souls overseas could give 2 ****s about how fast your car is in a straight line.
America's obsession with the 1/4 mile is very similar to it's stupid obsession with NASCRAP.
Real drivers turn right too!
Old Mar 12, 2003 | 04:58 PM
  #57
Nzo's Avatar
Nzo
My point is that no one cares and plenty of people do it far better. You obviously have no experience with cars in other countries or else you would not make uninformed statments like this:
I also went ahead and called you ignorant because you asked a question immediately after shiv had just spent a whole post explaining the answer.
Old Mar 12, 2003 | 04:59 PM
  #58
rdrkt's Avatar
They make some great WRX stuff over in Australia
How about JUN Auto?
Overhyped over priced. If you have a bottomless wallet and want to go with them that fine. But there are so many companies out there that deliver better products substantially cheaper.
Oh and because I like to go fast that is some how unsophisticated give me a freaking break. Usually people that cant build fast cars like to talk about handling. I don’t like excuses just results. If you want to talk about handling where’s the lap times?
Yes they do. Yes I have NASA open track events at Summit Point SCCA autocrossing. Its fun but drag racing is much easier/cheaper.
Old Mar 12, 2003 | 05:03 PM
  #59
rdrkt's Avatar
I consider myself an enthusiast I try to keep up to date on things the best I can. If someone is doing something better overseas that I can use then that is a good thing. But I havent seen anything substantially faster come out of Australia. That’s all Im saying.
Take a look at the post times. We must have been typing at the same time.
Old Mar 12, 2003 | 05:09 PM
  #60
rollo's Avatar
Originally posted by shiv@vishnu
The cars we've tested actually put ~180 hp to the wheels. The very same way air-cooled 911 Turbos put 300-310hp to the wheels. Horsepower is a quantifiable unit of measurment- just like an inch, meter or pound. Our dyno measures it properly. This is not hard to do with the necessary components and design.
Thanks for the reply and the explanation. I realised what I should have said was "Does it feel like a car with what you know as 180 horse to the wheel?" or something like that. Cos as you point out, your dyno puts out low numbers, compared to what we're used to seeing. What is your percentage adjustment for crank hp? (seeing as that is the quoted manufacturer 'standard', cos it's the higher number ); or do you not do that in the interests of accuracy? The problem is with the viral nature of the internet, that all that comes out is the number, and then Evo owners have to deal with "I heard your car makes 100hp less than claimed". Oh well, more fool them when they're lined up next door on the strip or trying to pass out of turn 11 at Laguna Seca
One thing I was wondering, which you may have mentioned somewhere else. What was the ambient temp, and was the IC sprayer on auto, switched off, or being used manually. I'm sure you had a fan on it, and MMC really seem to rate (inter)cooling and airflow at a high priority.
