Dyno results from Performance Autowerks...
Old Oct 8, 2005 | 12:13 PM
Dan2510's Avatar
Great guys over there big Thanks to Mike and Dave. My dyno was done on a mustang dyno here are the results, I'm bone stock to the filter:
2005 Evo 8
HP: 234.4
Torque: 272.0
Maybe Mike or Dave can post my graph for me.
Thanks guys
Old Oct 8, 2005 | 12:28 PM
Warrtalon's Avatar
2005 Evo 8
HP: 234.4
Torque: 272.0
Thanks guys
Sorry, but those numbers are useless for posting on the Internet. You should instruct them to fix their settings or just not bother going there again really. The only reason to go back there is to compare your numbers AFTER mods just to see the difference. If you try to compare those numbers with anyone else in the country, it just won't work, since those numbes are incredibly inflated for a Mustang Dyno.
Old Oct 8, 2005 | 12:30 PM
Dan2510's Avatar
Dang I thought I got some good numbers to.
Old Oct 8, 2005 | 12:31 PM
Turbojunkie's Avatar
Warrtalon, your allways so nice to people.
Old Oct 8, 2005 | 12:32 PM
Dan2510's Avatar
He keeps it real
Old Oct 8, 2005 | 12:35 PM
Precision Dyno's Avatar
I have never seen a Mustang dyno put down those numbers bone stock. Either the MD is setup to read like a dynojet or something is not reading right.
Trust me I have dynoed 50+ evos on my MD.
Old Oct 8, 2005 | 12:36 PM
Dan2510's Avatar
So my numbers would be better compared to a dynojet then a MD? Wow, so basically I paid for inaccurate readings...
Old Oct 8, 2005 | 12:37 PM
do a search, it all in how the operator sets up the dyno. he can get just about what ever numbers he wants you to get.
evoland's Avatar
nice work warrtalon!!
Old Oct 8, 2005 | 12:38 PM
Your numbers are completely inflated. BIG TIME
Old Oct 8, 2005 | 12:40 PM
Dan2510's Avatar
I'm just pissed now that blows. I mean I paid for a service that has been alterd to make me happy. Well AMS is Oct 29th I'll try theres out..
Old Oct 8, 2005 | 12:42 PM
Correct. The MD's across the country would read pretty close to each other if they would just leave the load cell and inertia levels alone. Instead they increase them for peak numbers.
The dyno can easily be calibrated once it is at the location. That number should be used ALL THE TIME. (2WDhas one and AWD has another)
We have never changed ours since it was installed.
Customers complain all the time about the end result.
I would rather have an accurate load reading then a calculated number based on thoeretical and false inertial values.
Old Oct 8, 2005 | 12:43 PM
It is a dynojet bud.... The numbers will make you happy as well.
Old Oct 8, 2005 | 12:46 PM
I would rather have an accurate load reading then a calculated number based on thoeretical ans false inertial values.
yes, this why you see guys all the time claming to have 350+ whp dyno sheets and 13.xx 1/4 mile time slips. get your "real" numbers and them start building from there. try and use the same dyno for each upgade also. if its set right and you go back to the same one after each( or whatever) mod you do you're getting the most accurate results. my 02 anyway.
Old Oct 8, 2005 | 12:49 PM
You are 100% correct.
