Boost Gauge vs. Dimmer wires
Old Oct 26, 2005 | 10:39 AM
Stew's Avatar
Originally Posted by burtomr
Anyone care to respond?
Sure. My D gauge dims. There is no possible way I am imagining dimming. Granted it still dims opposite the dash (I havent tried the other wire combo yet, been busy) but it dims.
Old Oct 26, 2005 | 11:06 AM
AWDrift07's Avatar
+1 The D-Gauge is not LED lit. The Defi Link Gauges are. I have the D-gauges but mine are not dimmable.
Old Oct 26, 2005 | 11:26 AM
Jakeg97's Avatar
. Who has a boost gauge wired into the dimmer, and what wires did you go with? (no HIDs for me as a sidenote, if that matters)..
green
https://www.evolutionm.net/forums/sh...ad.php?t=98114
Old Dec 28, 2005 | 11:23 AM
BQuicksilver's Avatar
I hooked up my Defi Boost guage this weekend. Wired the Defi leads to the green/white and yellow/brown EVO dimmer wires. The guage dims with the dash lights. Cool!
Just double checking, you used a D Gauge and it dimmed WITH the dash (not opposite it) via hooking the black defi lead to the green/white, and white defi lead to the yellow/brown, or vice-versa?
Old Dec 28, 2005 | 12:11 PM
Aux.'s Avatar
Factory instruction say that the gauge will not dim, play with fire and your gauge will get burned. So products are not used to the voltage difference and may work for 5 days or 5000 but (as an Electrician) i tend to stick with what the instruction say, i have a Defi D-gauge.
Old Dec 28, 2005 | 12:16 PM
nj1266's Avatar
I did what you said. Installed it yesterday w/o dimming. Grounded the black defi wire to the chassis and tapped into the dimmer for light only. No dimming for me since the instructions say that the gauge does not dim. BTW, my gauge boosts to 22 psi at WOT and then tapers down to 17 psi. I hope that is normal on the 05 EVO.
Old Dec 28, 2005 | 12:23 PM
Stew's Avatar
perfectly normal
I'll keep my dimming thank you very much, warning noted
Assassin
10
Apr 6, 2023 12:14 PM
silverevo05
Sep 1, 2010 10:12 AM
Need4Spd
Jul 18, 2009 10:56 PM
Thegame
Mar 26, 2006 06:59 AM
mikenjulie
Dec 28, 2005 12:16 PM
