Boost Gauge vs. Dimmer wires
Old Oct 11, 2005 | 07:08 AM
Stew's Avatar
..been through the search, read about 45 threads that didnt answer my question so I'll slap it up here..
Wired up a Defi Boost gauge this weekend and tapped the wires into the dimmer switch.. There are three wires feeding the dimmer switch, Black, Green and Brown. For shtis and grins I tapped my ground into the black wire (yea yea I know, should use another ground) and the other wire to the brown, since I was feeling lucky. Now, the boost gauge & HVAC background lighting dims directly opposite of the Dash. Kind of neat since I can dim the dash and have the boost gauge all lit up (sticks out nicely) and vice versa for just cruising.. BUT, I should probably make it work right..
Anyway, I've read in some other threads that if you tap the green wire of the dimmer switch, the gauge will have power but not be dim-able? Who has a boost gauge wired into the dimmer, and what wires did you go with? (no HIDs for me as a sidenote, if that matters)..
Old Oct 11, 2005 | 07:25 AM
Mike@Forge's Avatar
This is a good question.
Bump for an answer, and because I'm an electronics retard!
Old Oct 11, 2005 | 08:46 AM
rsboy's Avatar
hmmm.. never tried the dimmer switch wires. After all the bs I went through trying to figure out which wires to use for my Defi Control Unit and BF boost gauge, per friends' suggestions, I went and tapped into the stereo harness wires. So much more easier. And since the harness had labels... it helped ALOT!
But on my old mechanical Blitz gauge, I just tapped into one of the power wires near the fuse box area and grounded to a bolt behind the kick panel. The gauge didn't have a dimmer just on and off with the parking lights.
Old Oct 11, 2005 | 08:59 AM
ibanez_926's Avatar
i tapped the green/white stripe wire. its been so dam long since i drove my car, but i am pretty sure it is not dimable
Old Oct 11, 2005 | 09:04 AM
Stew's Avatar
...well so far we know:
Brown (power) + Black (ground) = Reverse dimable (this also effects the radio and heating/AC lighting)
Green (power) + Black (ground) = Has power, but no dimming.
there must be someone who has a properly dimming boost gauge, you wouldnt think it would be that difficult..
Old Oct 11, 2005 | 09:09 AM
dbdude's Avatar
I did the green and it does not dim on my gauge. For ground i just unbolted a screw under the dash and went with that.
Old Oct 11, 2005 | 09:35 AM
bigfishs's Avatar
Pretty sure I saw the answer to this in the how to's discussion bit. I'll try and find the thread
Old Oct 11, 2005 | 09:36 AM
Ultimate CC's Avatar
Here is the trick, I am almost 100% that brown is power and then you tap the black for ground. It may be diff colors on your car since I have a 05 but if you tap the center one of the three for ground and the right one for power (its the wire thats not green).
Dan
Old Oct 11, 2005 | 09:37 AM
Monkey's Avatar
I don't remember what wires I tapped into, but my Defi isn't dimmable. I probably tapped the wrong wires.
Old Oct 11, 2005 | 09:50 AM
bigfishs's Avatar
It is discussed on the second and third pages of
https://www.evolutionm.net/forums/sh...2&page=3&pp=15
Tap the yellow/black wire with one tap and the green white with the other
Old Oct 11, 2005 | 10:37 AM
Stew's Avatar
Dan
I have a 05 as well.. looks like in that thread that was linked above that another 05 driver tapped the green and the black, and has propper dimming.. Maybe this color combo works in the 05 and not in the 03 like above? I'll swap wires later today/tomorrow and report back..
Old Oct 11, 2005 | 12:02 PM
beavis4g63t's Avatar
There are three wires that go to the dimmer switch. two have power and one is a ground. you need to tap the two wires for the boost gauge light into the the two power wires. you will either get it right on the first try or notice that your gauge dims in reverse of the dash lights. if it dims in reverse just switch the wires. if you still have trouble i'll go look at my 03 later and get you the exact colors. this is only for the light. if you need a ground for the gauge (egt or something else) use a chassis ground. only the lights for the gauges should be hooked up in this manner.
Old Oct 11, 2005 | 01:27 PM
Stew's Avatar
so,
Black Defi wire -> brown (power) dimmer wire
white Defi wire -> green (power) dimmer wire
nothing -> black dimmer wire
(or vice versa on the black/white wires)
I'll give that a shot
Old Oct 11, 2005 | 02:54 PM
burtomr's Avatar
Boy is this a confusing subject!! So, has anybody SUCCESSFULLY got their guage to dim yet?? Which wires did you use?
Choices: Dimmer Wires are: (1) Black (2) Brown/Yellow (3) Green/White
Please post your results. Thanx!
Old Oct 20, 2005 | 04:01 PM
burtomr's Avatar
I hooked up my Defi Boost guage this weekend. Wired the Defi leads to the green/white and yellow/brown EVO dimmer wires. The guage dims with the dash lights. Cool!
Last edited by burtomr; Nov 15, 2005 at 12:14 PM. Reason: Real world experience...
