AWD + Snow Tires + ACD (snow mode) + Tire Chains = Overkill??
if you think you need chains get a studded tire.
i ran these last year on my wrx....RSI. http://www.nokiantires.com/newsite/t...fm?cid=1&sid=1
Originally Posted by markeddy
Can someone explain what the % distribution is for all 3 ACD modes?
Thanks!
Thanks!
Originally Posted by raywong
Tarmac: 50/50
Snow: 50/50
Gravel: 50/50
The center diff has a fixed ratio gearing, which is 50/50.
The ACD mode varies the diff's lock state duration and locking power only. In the entrance of a turn, the diff change from open to lock to provide lateral stability. In the middle of the turn, the diff opens to induce turnning. In the exit of the turn, ACD locks the diff again to provide maxium exit stability.
Tarmac: the ACD stay lock for short duration
Gravel: the ACD stay lock for medium duration
Snow: the ACD stay lock for long duration, lowest locking power.
Snow: 50/50
Gravel: 50/50
Originally Posted by ashumo
ACD locks front and rear 50/50 whole time. (NO torq split, ACD never splits torq)
How ACD works:
When you turn the wheel in Tarmac mod-The ACD opens instantly
When you turn the wheel in Gravel mod-The ACD takes 2 to 3 seconds to open
When you turn the wheel in Snow mod-The ACD takes 4-5 seconds to open
SEARCH:
https://www.evolutionm.net/forums/sh...&highlight=ACD
https://www.evolutionm.net/forums/sh...5&page=1&pp=15
http://www.mitsubishi-motors.com/cor...001/13E_09.pdf
How ACD works:
SEARCH:
yo, person who posted this comment whoever it was, dont get special tires. stick to stock bro youll be fine save that money for a mod to go faster. i ran stock tires in 4-5 of fresh wet snow on tha road about 50 miles in tha middle of wyomnig. your fine just try and stay outta tha turbo range, and drive pretty slow. and if you start to slide pull your handbrake to direct you into tha direction you want to go incase your nose turned for tha worse. late
james
james
james
james
I would consider this terrible advice.
g3mccotter that was great...id love to see you perform this action while on I-90 during a cold icy windy night.
i live in the same area as justchil, and what's worse is i am lowered. i used stock tires all season last winter, and had no problems what so ever. if the roads get real bad, i take it easy until i find a open parking lot or nice wide stretch of road to have some fun on!
pcguru2000
Jun 21, 2011 10:43 AM
kf6ytc
19
Dec 9, 2005 09:02 AM
oheresy
Apr 27, 2003 01:29 AM
