cigarette lighter socket bad?
Old Oct 17, 2005 | 03:03 PM
03SilvaEvo's Avatar
My cig lighter socket is acting up. I plug my SIRIUS receiver to it and everytime I hit a sharp bump the receiver turns off and then back on again and I think its the socket. I can wiggle the receivers power plug while plugged in socket and the receiver will turn off then on again. Fuse on the receiver power cable is still good.
Old Oct 17, 2005 | 06:15 PM
03SilvaEvo's Avatar
ttt
Old Oct 17, 2005 | 06:20 PM
BuLocal's Avatar
I would try and plug something else into it and see if you have the same problem. It may just be the the plug from your SIRIUS isnt making good contact. Example: I plug my Valentine1 into the Evo no problem, plug it into my wifes Civic and I have problems like yours.
Old Oct 17, 2005 | 06:40 PM
br3ds0x's Avatar
ya i agree try something else in there...my phone charger for some reason wont work in my evo but works in other cars..but my valentine and ipod charger both work fine..
Old Oct 17, 2005 | 06:42 PM
BoostWhore's Avatar
more than likely the plug is the problem. You can check the socket and make sure that it is clean. Also maybe the connection is loose underneath the console where it plugs in doubt it though
Old Oct 17, 2005 | 06:44 PM
blueo4's Avatar
trust me it is the fuse under the inside fuse box! chect it!
Old Oct 17, 2005 | 07:20 PM
03SilvaEvo's Avatar
I notice when I press the plug all the way til it can go further the receiver turns off.
Old Oct 17, 2005 | 08:27 PM
Nvalenti20's Avatar
Speaking of the cigarette lighter (maybe a little off topic) but the fuse for my cigarette lighter keeps blowing.......I'll change the fuse and for like 5 mins it'll work, then it will blow, even if I put a 20amp in there. I don't want to go more than that because I figure theres a reason its blowing and I don't want to screw something up if its trying to tell me something.....any ideas anyone?
Old Oct 19, 2005 | 04:49 PM
03SilvaEvo's Avatar
Yes! I found the problem! It was a damn loose connection right behind the socket. No turning oof now when I go over bumps!
EVLX
Aug 31, 2015 02:29 PM
Sir_Lancer_Lots
Lancer Troubleshooting
15
Apr 8, 2014 08:14 PM
plastus
Dec 27, 2012 07:05 AM
MrBRoced
Nov 18, 2012 07:01 PM
XstormtrooperX
10
Jun 1, 2012 03:24 PM
