difference between whp and engine hp?
Old Oct 23, 2005 | 09:58 PM
sirloin1219's Avatar
alright i know this has been covered and i tried serching for it. but i wasnt sure exactly what criteria i should type in the search box. so i figured ill just ask. what much horsepower is lost from the engine to the wheels on the evo? i know it's different since it's awd. but can someone please chime in. thx!
Old Oct 23, 2005 | 10:01 PM
mr96gsx408's Avatar
85% of all internet statistics are made up.
that being said... horsepower is just a estimation. It's defined as 1 hp = 745.x watts. From the factory, the Flywheel horsepower is 270ish for a evo (taken from mitsubishi). An evo, depending on the dyno makes 220ish more or less. So if you passed high school algebra, you can calculate the drivetrain loss.
More info: google it. here i'll do it for you:
http://en.wikipedia.org/wiki/Horsepower
AtO-MiX's Avatar
i think both the Evo and the Sti lose about 30% since we are awd...then again i could be completely wrong i too would like to know the exact amount
Old Oct 23, 2005 | 10:02 PM
autoplus's Avatar
I believe around 15 to 20% is lost from the flywheel to the wheels.
Old Oct 23, 2005 | 10:05 PM
Jabba08's Avatar
I've heard 17%
Jin4g63's Avatar
how would you calculate the drivetrain's lose i was sleeping in algebra class
Old Oct 23, 2005 | 10:08 PM
joseph k's Avatar
I've heard 95%, see I can do it too. I think he wanted something a little more concrete.
Old Oct 23, 2005 | 10:10 PM
Warrtalon's Avatar
(270-220)/270 = 50/270 = 18.5%
This is just an estimate and is not factual. The only way to get the true difference is to dyno the engine itself outside of the car, then dyno it inside the car through the wheels. This parasitic loss will be some % but won't always be the same and is not linear as you add HP.
Old Oct 23, 2005 | 10:12 PM
well if my algebra is still good from high school, then the drivetrain loss is about 20-21% according to my calculations.
Sam - PURE Tuning's Avatar
Former Vendor
also depends on what dyno you use
