geddy 25g on a mustang dyno
Old Nov 16, 2005 | 05:15 PM
  #31
TURBODAWG's Avatar
Check this thread out from back in the day. https://www.evolutionm.net/forums/sh...ad.php?t=71294
I ran three runs in th 118+ mph range.
Stock FMIC and piping
Stock injectors
Completely Stock turbo
264 cams
Dynoflash mail in
HKS Super AFR
HKS Super mega flow
Greddy Type S bov
B&M shifter
B&B catback, with testpipe and Helix dp
I cant believe that my car was making 390 whp. By everyones arguments on here, the MPH supports the claim.
This is the exact same track that blowoffsilver ran his car at and ran this time.
I did alot more to the car and never got it to run that fast again. The most power it ever made with more mods was 367 whp and 384 ft lbs on a dynojet in Johnson City TN.
Brian
Old Nov 16, 2005 | 05:21 PM
  #32
Warrtalon's Avatar
Yeah, I used to always trap 3mph higher at Rockingham. People always said it was downhill. I also never could hook as well there as I did at other tracks, very much like what you experienced in that thread.
Old Nov 17, 2005 | 01:39 PM
  #33
TTP Engineering's Avatar
Originally Posted by Warrelton
Jose Rivera (down your way) dyno'd 373 and trapped 116.7mph
On a "true Mustang Dyno" pre-recalibrated. That is my .02 ....
Originally Posted by Topspeed Doug
Edit: don't forget that we aren't just talking about peak hp numbers... anytime you install a larger turbo the peak numbers may remain the same but the hp curves don't drop down as far.. leaving more power in the upper rpms which helps run faster times.
Excellent point Doug which you can assume 280's on a stock turbo at 8200rpms does not have very much boost to supply the motor and why the dyno's look like a rainbow. To prove this point, we shifted to 5th last night and achieved 117.44mph. We do have the MAFTPro now, however we can actually use the higher boost/lower rpm and lean out the a/f where we could not on the MAF/SAFC without making the preceding gears tune too lean which is what would happen on SAFC.
Old Nov 17, 2005 | 01:59 PM
  #34
blowoffsilver's Avatar
i do wont to get doug to tune the car because i think the timing map is def screw up so hopefully soon if i do not sell the kit then i will go to topspeed and let him play with the ecutek on it to see how it does compared to the ****ty tune i have now from some person that tunes stock ecus, not saying any names. also i think i was running out of 4th gear before the line.
Old Nov 19, 2005 | 06:20 PM
  #35
ok got the sheets posted up on the first post
TURBODAWG
39
May 14, 2008 05:18 PM
jcdevo67
18
May 4, 2007 07:04 AM
blowoffsilver
36
Apr 18, 2006 01:47 PM
TURBODAWG
73
Feb 9, 2006 08:38 AM
David Buschur
736
Sep 21, 2005 09:39 AM
