geddy 25g on a mustang dyno
Old Nov 9, 2005 | 02:59 PM
blowoffsilver's Avatar
ok we dyno the greedy kit on monday night heres my mods
greddy 25g kit
3inch turbo back
hks 264intake 272exhaust
greddy front mount
super afc
greddy boost controller
flashed ecu
k&n filter with custom mass pipe
8.5mm wires
walbro fuel pump
at 20 psi it made 322hp and 291tor
at 25 psi it made 393hp and 340tor
at 28 psi it made 445hp and 370tor
with straight 110octane it seem to hold timing perfect and knock was pretty on the afc controller, it peek around 70s. but i am real happy with it, it felt really good on the road afterwards. were are taking it to rockingham, in hopes to turn 120mph or plus.
i would like to say thanks to turbodawg, chris, and josh for all of their had work on the install and tuning. i hope to get the sheets up in the next couple of days. no scanner so im taking them to turbodawg if he can do it for me.
the mustang dyno numbers is kind of low but we think it would be close to 500 at the wheels and over 550 at the crank.
i got to say the turbo is laggy but i like it pretty good.
heres the sheets.
Old Nov 9, 2005 | 03:03 PM
platinumspecv's Avatar
So what kind of #'s would u run on pump gas....93 octane?
Old Nov 9, 2005 | 03:05 PM
matt55's Avatar
I dont think 120mph will be a problem
Old Nov 9, 2005 | 03:07 PM
at 19 which is what i run on the street on 93 i would hope it is real close or better than the 322
Old Nov 9, 2005 | 10:53 PM
Ivan MR's Avatar
Any graphs?
Old Nov 9, 2005 | 11:00 PM
forum04pl's Avatar
yeah what kind of dyno, and also when do you see full boost with the 25g?
Old Nov 10, 2005 | 05:58 AM
4TUN8's Avatar
I'm no pro, and I don't know alot...but maybe the A/R is too high? Seems like you're not making good power unless you're running high boost...Lemme see the dyno charts, because that is what will really show us what's going on....Better yet, take it to the track and run it, that'd be more standard....
Old Nov 10, 2005 | 06:05 AM
TURBODAWG's Avatar
Mitsubishi does lists A/R in a different method than most other people. The equivalent A/R for the Greddy T67 25G is a 10cm. This is slightly smaller in nozzle area than the 10.5 housing that is on the stock 16G6 turbo on a stock 2005 or newer Evo. There is an alternative size that is even smaller, a 8cm nozzle area. The turbo that he is using here is the 10cm unit.
I will get the scans of the dyno runs done as soon as he brings me the dyno sheets.
Brian
Old Nov 10, 2005 | 07:32 PM
94AWDcoupe's Avatar
The 25g spools faster and is a very enjoyable turbo with the 8cm housing. The turbo has a bad name because everyone gets it with the 10cm. I know many accounts of the 8cm/25g laying down 525whp plus. There is no benifit to the 10cm. Just slower spool. You cant compare twin scroll numbers to single scroll numbers. A 10cm twin scroll prolly has more backpressure than a 8cm single.
Old Nov 11, 2005 | 01:47 PM
it reachs full boost at 4800 to 5000
am im trying to get the sheets to turbodawg, but went to the track last night 1/8 mile it went 1.8 60foot 7.56at96.4mph which i thought was real good on the stock clutch
Old Nov 11, 2005 | 01:57 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Nice time for just an OK 60ft.
Old Nov 11, 2005 | 02:14 PM
yea the clutch held up pretty good but the last run i tried to launch around 5500rpm and it didnt hold for **** . i am surprize it held up for a 1.7 60foot
Old Nov 11, 2005 | 02:44 PM
Warrtalon's Avatar
Hell, who cares about the time? It's only .1 faster than I am, but that MPH realllllly shows the power. Holy crap, 96+ mph on a crap launch shows some definite power!
Old Nov 15, 2005 | 03:49 PM
yea it went 121 in the 1/4 saturday night at rockingham, the dyno sheets and timeslips should be up by saturday
Old Nov 15, 2005 | 03:57 PM
Warrtalon's Avatar
Very nice mph. That indicates about 410-420whp on a Dynojet.
